Engine Tool
19 replies to this topic
#1 drbish ONLINE
drbish
    Collecter
  • 1,557 Thanks
  • 1,361 posts
Posted August 24, 2015 - 05:28 PM
I got this in some small engine parts,Still in the box with a service bulletin.I thought i would throw this out for a guess as what it was for.The bulletin is dated 3-10-55
  • nelljg60, nanetteoy69 and youngsi18 have said thanks
#2 UncleWillie ONLINE
  • 15,660 Thanks
  • 8,758 posts
Posted August 24, 2015 - 06:29 PM
Oil slinger?
#3 drbish ONLINE
drbish
    Collecter
  • 1,557 Thanks
  • 1,361 posts
Posted August 24, 2015 - 06:31 PM
a tool not a part
  • UncleWillie said thank you
#4 Cat385B ONLINE
    HAZMAT CAT
  • 13,966 Thanks
  • 9,998 posts
Posted August 24, 2015 - 07:01 PM
Combo feeler gauge and spark plug gapper?
#5 UncleWillie ONLINE
  • 15,660 Thanks
  • 8,758 posts
Posted August 24, 2015 - 07:20 PM
a tool not a part
Ok I change my answer to a back scratcher for a smurf
#6 Cvans ONLINE
  • 6,630 Thanks
  • 6,123 posts
Posted August 24, 2015 - 07:21 PM
For setting valve clearances on adjustable lifters.
Edited by Cvans, August 24, 2015 - 07:22 PM.
#7 backyardtinker OFFLINE
backyardtinker
  • 249 Thanks
  • 182 posts
Posted August 24, 2015 - 07:34 PM
:ditto: was my first guess.......
#8 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted August 24, 2015 - 07:41 PM
I would guess, without knowing the thickness, that it's a gauge for setting the clearance on a magneto.
#9 chieffan ONLINE
  • 10,095 Thanks
  • 6,617 posts
Posted August 24, 2015 - 07:42 PM
How about a small screw holder?
#10 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,281 Thanks
  • 9,771 posts
Posted August 24, 2015 - 08:09 PM
Slim Jim for car locks
#11 propane1 ONLINE
propane1
  • 8,708 Thanks
  • 4,121 posts
Posted August 24, 2015 - 08:26 PM
High speed jet adjustment tool for the carb. ??? Noel
#12 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted August 24, 2015 - 09:05 PM
If you had ever dropped a point or condenser retaining screw into a distributor and had to pull the distributor to get it out.
That slot would be a blessing.
My Dad about had a heart attack when he came home and I had the distributor out of my new 70 Plymouth Duster during it's first tune up. It was almost as bad as the time I backed out the torsion bar bolts to lower the front end 3 inches.
Edited by JD DANNELS, August 24, 2015 - 09:10 PM.
#13 framesteer OFFLINE
framesteer
  • 419 Thanks
  • 200 posts
Posted August 24, 2015 - 09:38 PM
Tool to depress the spring on top of B&S condenser that holds the wires in the hole in the condenser contact post
  • olcowhand said thank you
#14 drbish ONLINE
drbish
    Collecter
  • 1,557 Thanks
  • 1,361 posts
Posted August 25, 2015 - 03:25 AM
no right answer yet,it is a briggs part,
#15 1oldbuzz OFFLINE
1oldbuzz
  • 564 Thanks
  • 448 posts
Posted August 25, 2015 - 05:31 AM
Tool to remove the points plunger
