John Deere 214 voltage regulator
3 replies to this topic
#1 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted August 24, 2015 - 12:25 PM
What are the symptoms of a bad voltage regulator? Got a 214 that was on fire and burnt the hood off and melted some of the wire coating off. Taped up wires, and engine turned over for several start attemps, and then suddenly quit. Put new wiring harness in it and 99.9% sure it's right, with the exception of the 2 safety switches, which I bypassed by wiring 2 wires together. If the voltage regulator is bad will engine even turn over? Right now it does nothing and makes no noise at all?
#2 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,982 Thanks
  • 2,476 posts
Posted August 24, 2015 - 12:28 PM
The voltage regulator is part of the charging system, NOT the starting system.
However, if something is mis-wired, or shorted to ground, all bets are off.
#3 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted August 24, 2015 - 01:04 PM
Here is how I bypassed 2 safety switches. Yah I know it's not safe but just wondered if this would be ok to see if it turns engine over? Could it be the solenoid? It doesn't click or anything?
#4 Trav1s ONLINE
Trav1s
  • 3,577 Thanks
  • 4,550 posts
Posted August 29, 2015 - 09:14 AM
A tractor will start and run if the voltage reg is bad or is removed.  The ignition system on your 214 draws voltage for spark from the battery.
