New to me squire 10
11 replies to this topic
#1 Banjo123 OFFLINE
Banjo123
  • 17 Thanks
  • 72 posts
Posted August 24, 2015 - 08:13 AM
hey everybody. I'm a new memeber to this site but I have read lots of material on here in the past. Very helpful. Anyway, I bought a 1965 squire 10 this past weekend. It seems to be a great tractor just needs a little work. First off, while greasing the zerk on the right axle housing, I noticed grease came out of the left side housing. Is that ok? I also need to rebuild the bgb so I may be posting about that in the future. Thanks in advance.
#2 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted August 24, 2015 - 10:09 AM
Great tractor
#3 HDWildBill OFFLINE
  • 8,984 Thanks
Welcome to GTtalk.  I'm not familiar with the Square 10 but I'm sure some one who is will be by before long to answer your question.  Also please check out our manuals section.
#4 HANKG OFFLINE
HANKG
  • 6,597 Thanks
  • 3,530 posts
Posted August 24, 2015 - 12:35 PM
Welcome aboard lot of nice and knowledgeable people here what is a bgb?
#5 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted August 24, 2015 - 12:41 PM
:welcometogttalk: :camera:
#6 Banjo123 OFFLINE
Banjo123
  • 17 Thanks
  • 72 posts
Posted August 24, 2015 - 01:41 PM
Thank you guys!
#7 classic ONLINE
classic
  • 5,634 Thanks
  • 2,351 posts
Posted August 24, 2015 - 05:45 PM
Yes, grease should come out of both ends of the axle when you pump grease into the fitting on the axle tube. The axle passes through a bushed tube. The axle, external differential, and inner axle tube bushings are lubed with grease. The tube itself, passes through the transaxle housing which is bushed. The transaxle housing bushings and the outer axle tube are lubed with gear oil. The outer axle tube passes through seals that are pressed into the transaxle housing and retain the gear oil.
There are a few threads regarding the BGB (bevel gear box) rebuild. You can also ask questions here and search online for more info when the time comes.
Edited by classic, August 24, 2015 - 06:03 PM.
#8 KC9KAS OFFLINE
KC9KAS
  • 5,469 Thanks
  • 4,725 posts
Posted August 24, 2015 - 06:07 PM
:welcometogttalk: , and :wewantpics:
#9 Talntedmrgreen OFFLINE
  • 3,290 Thanks
  • 2,316 posts
Posted August 24, 2015 - 09:15 PM
Welcome! Squires are one of my personal favorites and a treat to find. Congrats! Cant wait to see it!
#10 Banjo123 OFFLINE
Banjo123
  • 17 Thanks
  • 72 posts
Posted August 24, 2015 - 10:16 PM
I'll work on getting some pics up. I'm really tickled to death with this tractor. I only saw grease come out of the left side. Maybe I should just keep pumping unti it comes out the right side as well?
#11 classic ONLINE
classic
  • 5,634 Thanks
  • 2,351 posts
Posted August 25, 2015 - 12:58 AM
You may see grease come out, just to the right of the grease fitting on the axle tube. Usually, grease will seep out of this area after you pump grease into the axle tube, then use the tractor for a while.
#12 Banjo123 OFFLINE
Banjo123
  • 17 Thanks
  • 72 posts
Posted August 25, 2015 - 07:08 AM
Ok. I didn't see any come out the right side. Just the left. That's why I thought it was strange. Just wanted to make sure I did break a seal or something. Thanks for the help.
