plow angle
4 replies to this topic
#1 lil misfit OFFLINE
lil misfit
  • 2 Thanks
  • 15 posts
Posted August 24, 2015 - 07:42 AM
Hi all, I have a 14 inch furrow that I would like to build a 3 pt frame for to use as a tater plow. Could anyone give the approx angle for the bend where the plow attaches at the bottom?
#2 boyscout862 ONLINE
  • 13,554 Thanks
  • 9,430 posts
Posted August 24, 2015 - 08:25 AM
I do not know the answer to your question. I would think that if you made the frame so that the angle is adjustable you would be much better off. Good Luck, Rick
  • lil misfit said thank you
#3 Cvans ONLINE
  • 7,296 Thanks
  • 6,382 posts
Posted August 24, 2015 - 09:21 AM
I just cut one bottom off of a 2 bottom plow and used that. Seemed to work fine. Mine was a pull type with a ground driven lift.
This photo is similar to what mine would have looked like.
jd-one-bottom-pull-type-plow-360-republi
Edited by Cvans, August 24, 2015 - 09:24 AM.
  • boyscout862 and lil misfit have said thanks
#4 lil misfit OFFLINE
lil misfit
  • 2 Thanks
  • 15 posts
Posted August 24, 2015 - 12:07 PM
Thanks guys, I'm kinda going from scratch with the framework for it . I was just wondering as most pics I've seen the plow seems to be around 20-30 degees on the older fixed plows.
  • Cvans said thank you
#5 MH81 OFFLINE
  • 29,979 Thanks
Posted August 24, 2015 - 09:18 PM
The brinly Plows were 10 degrees.
