Pulley Removal
23 replies to this topic
#16 bbuckler ONLINE
bbuckler
  • 3,433 Thanks
  • 3,047 posts
Posted August 25, 2015 - 10:10 PM
  Too late for this one, but next time drill two 5/16" or 3/8" holes 180* apart about 1/2" from the hub. then use the harbor freight puller like pictured or a two jaw puller w/ the jaws that fit over a bolt. May still require some heat but the pulley will survive.
                                                   Mike
A jaw puller did the damage even after it was heated.
#17 dodge trucker ONLINE
dodge trucker
  • 2,429 Thanks
  • 3,121 posts
Posted August 25, 2015 - 11:39 PM
yeah a jaw puller on a pulley like that will damage your pulley every time; those pullies aren't that strong, it takes relative "nothing" to bend them.
#18 Alc OFFLINE
  • 6,884 Thanks
  • 7,459 posts
Posted August 26, 2015 - 05:26 AM
It's too bad the pulleys didn't come with a grove around the hub like there are on car p/s pulleys or threaded holes in the hub ( might not be able on that small of hub )
#19 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted August 26, 2015 - 07:13 AM
  I don't see any holes drilled close to the hub for bolts.
                                           Mike
#20 bbuckler ONLINE
bbuckler
  • 3,433 Thanks
  • 3,047 posts
Posted August 26, 2015 - 09:26 AM
Mike
#21 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted August 26, 2015 - 10:00 AM
  Understand this isn't a "told you so" or "I'm looking for a pi$$in' match", but please re-read post #15.
                                               Mike
#22 bbuckler ONLINE
bbuckler
  • 3,433 Thanks
  • 3,047 posts
Posted August 26, 2015 - 10:52 AM
                                               Mike
I'm just going to cut it off there is no saving it.
  • ol' stonebreaker said thank you
#23 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted August 26, 2015 - 03:32 PM
  I don't see any saving it either. I was just passing on info for the next one. I had to do the drill holes and bolts thing on my TB Horse wheels and it still took lots of O/A heat and torque to get both off right down to the last 1/2" and they survived quite well.
                                                Mike
  • bbuckler said thank you
#24 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted August 28, 2015 - 03:44 PM
Good Gravy, that thing is toast now for sure :D
