Pulley Removal
23 replies to this topic
#1 bbuckler ONLINE
bbuckler
  • 3,311 Thanks
  • 2,972 posts
Posted August 23, 2015 - 11:09 PM
Tried soaking it with wd40 , heat , puller and a hammer still can't get it off. Any tips on how to remove it ?
#2 boyscout862 ONLINE
  • 12,518 Thanks
  • 9,028 posts
Posted August 24, 2015 - 12:02 AM
Use PB Blaster or the homebrew on our home page. Allow some time. Good Luck, Rick
Try: http://gardentractor...pb-blaster-r149
Edited by boyscout862, August 24, 2015 - 12:05 AM.
#3 KennyP ONLINE
  • 37,396 Thanks
  • 45,448 posts
Posted August 24, 2015 - 04:18 AM
I like the Acetone/ATF mix myself! 50/50 mix, seems to work well!
#4 dodge trucker OFFLINE
dodge trucker
  • 2,297 Thanks
  • 3,013 posts
Posted August 24, 2015 - 05:29 AM
take a punch and hammer and see if you can move the key at all, push it toward the inside (toward the motor) a bit.
of course if it has a "woodruff" key (the 1/2 moon ones) you wont be able to.
many times that is where your hang-up is with getting something off of a shaft.
  • HANKG said thank you
#5 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted August 24, 2015 - 07:13 AM
  A pic or two might help us help you.
                                 Mike
#6 bbuckler ONLINE
bbuckler
  • 3,311 Thanks
  • 2,972 posts
Posted August 24, 2015 - 07:24 AM
#7 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted August 24, 2015 - 07:31 AM
Since it's already destroyed, just cut it off.
  • dodge trucker and HANKG have said thanks
#8 Alc OFFLINE
  • 6,739 Thanks
  • 7,395 posts
Posted August 24, 2015 - 07:38 AM
Oh Boy !!   Hope your weren't going to use it over
#9 chieffan ONLINE
  • 9,530 Thanks
  • 6,395 posts
Posted August 24, 2015 - 07:48 AM
Definitely blue wrench time on that one.  Just don't get into the shaft.
#10 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted August 24, 2015 - 07:58 AM
If you don't have a torch, you can use a cutoff wheel. It takes much longer, but will get the job done. Good luck! :)
#11 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,852 Thanks
  • 4,347 posts
Posted August 24, 2015 - 08:04 AM
What is that pulley for? looks kinda light duty. I agree it will need cut off. I don't have a torch, but have used a cut-off wheel. carefull around the shaft threads, I would spin a bolt on there, then cut into the pully (and bolt) to a point just above the shaft then use a chiesel to split the pulley.
#12 EricFromPa ONLINE
EricFromPa
  • 3,513 Thanks
  • 3,064 posts
Posted August 24, 2015 - 08:17 AM
You could make a puller something like this one.
Drill 2 holes on the pulley and put nuts and washers on the back.I made mine out of a piece of 1/2" thick by 1 1/2" wide steel bar stock 6" long with 7 holes in it.I had to use grade 8 bolts and weld a nut on the back for the big center bolt and grind a point on it.
rough drawing of my home made puller.
You could use a Crows foot puller or Harmonic Balancer puller.Harbor Freight has them for $10-$15.
#13 bbuckler ONLINE
bbuckler
  • 3,311 Thanks
  • 2,972 posts
Posted August 24, 2015 - 08:48 AM
I already had to cut the nut off a couple days back
#14 dodge trucker OFFLINE
dodge trucker
  • 2,297 Thanks
  • 3,013 posts
Posted August 25, 2015 - 05:46 AM
once you get it down to the hub cut that at the keyway, if you cut into the key no big deal, rather trash that than the shaft.
  • Alc and bbuckler have said thanks
#15 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted August 25, 2015 - 09:33 PM
  Too late for this one, but next time drill two 5/16" or 3/8" holes 180* apart about 1/2" from the hub. then use the harbor freight puller like pictured or a two jaw puller w/ the jaws that fit over a bolt. May still require some heat but the pulley will survive.
                                                   Mike
