Must have gotten an extra spring in the kit, the spring goes into the needle and then the pin goes on top
Alot of these older carbs warp over time from people over tightening the bowl screws , I found a simple solution to this which is put a small dab of JB weld on the carb where you can see an opening, the remove simply wire wheel it off. Been doing that for years on these.
