SHORT grease zerks?
8 replies to this topic
#1 glgrumpy OFFLINE
  • 8,612 Thanks
  • 7,920 posts
Posted August 23, 2015 - 10:39 PM
Been working on Speedex's lately and they have lots of grease zerks, a good thing, I guess. BUT, I started just taking them out and tossing aside and wanted to put new ones in, just in case old ones were plugged tight. Well, have a whole assortment of them in the 1/4-20? sizes, but each one goes in too far and hits the shafts and locks them up. Where they go into the tubes is just the thickness of the tube, no build-up or thicker part. I ended up putting the old zerks back into the holes then and greased them up and all were good. SO, where does one find short threaded zerks and what special name might they have to ask about?  I bet if I ask locals they will look at me like I'm nuts or making this up. I have in past ground a groove in a shaft to clean the zerk when in, but I'm sure not gonna do all the ones on these rigs.
#2 lyall OFFLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted August 23, 2015 - 10:50 PM
I would try to find a machine shop supply house.  You might have the drive in type , not the screw in type.
If you can not find the ones you need, you might have to grind off the end of the zerk.
good luck
#3 glgrumpy OFFLINE
  • 8,612 Thanks
  • 7,920 posts
Posted August 23, 2015 - 10:59 PM
They have threads, just not many. I've heard of the drive-in type, don't get how they stay in???? Would break off easy with a gun used on them? Might try grinding end off, but man, will be hard to hold and keep in a tool doing that I bet.
#4 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted August 23, 2015 - 11:52 PM
McMaster-Carr has the straight 1/4"-28 grease fittings available in two length threads.
The short-thread fittings are # 1095K41,   The longer-thread fittings are # 1095K42.
  • Alc, boyscout862 and PGHsteelworker have said thanks
#5 MH81 OFFLINE
Posted August 24, 2015 - 06:20 AM
I've also seen washers under them.
#6 chieffan ONLINE
  • 10,165 Thanks
  • 6,647 posts
Posted August 24, 2015 - 07:53 AM
They can be held in a good vise grip and held against the side of an emery wheel so your grinding with a flat surface.  It don't take a lot, but be sure the hole is open when your done grinding.
#7 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,008 Thanks
  • 4,414 posts
Posted August 24, 2015 - 08:07 AM
Yep, mine have washers on the steering spendles.
#8 JBRamsey ONLINE
JBRamsey
  • 1,463 Thanks
  • 836 posts
Posted September 15, 2015 - 10:08 PM
The drive in type are like a press fit.
#9 glgrumpy OFFLINE
  • 8,612 Thanks
  • 7,920 posts
Posted September 17, 2015 - 05:29 PM
I found if I bought ones in Auto section they are shorter and work. The ones in the general hardware section or in parts drawers are the long tailed ones. Got them in and working fine now.
