John Deere Gator (1987)
11 replies to this topic
#1 jms180 ONLINE
jms180
  • 1,504 Thanks
  • 1,562 posts
Posted August 23, 2015 - 08:15 PM
I am trying to help a friend with this old ATM 600 with a no spark issue. The ignition system is a capacitive discharge ignition (CDI) the engine is a Kawasaki KF82D-X. The engine has an exciter coil and a pulser coil mounted under the flywheel. The exciter pack(CDI) is located under blower shroud cover. Parts are hard to come by and expensive. Has anyone changed these ignition systems over to a coil using a magnetic pickup. This engine was also used in club car golf carts. Any help please thanks
Edited by jms180, August 23, 2015 - 08:17 PM.
#2 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted August 23, 2015 - 10:15 PM
I know someone who did a conversion like that on a Club Car.  I remember he was pretty ticked with it after the fact since it never really ran quite right.  I don't think the timing was right.
Have you determined what exactly is wrong?  The CDI is usually what I am used to seeing fail on that type of set up.  If you pull any of the parts let me know what numbers are on it.  It is probably a fairly common Japanese ignition system, and you can probably get it elsewhere for about 30% of what Deere is asking.
Ben W.
  • jms180 said thank you
#3 jms180 ONLINE
jms180
  • 1,504 Thanks
  • 1,562 posts
Posted August 24, 2015 - 07:24 AM
Thanks Ben
Today I am going to check resistance on the pulser coil and the exciter coil. If resistance is ok then the CDI module is bad. The Kawasaki part number for the CDI is 316670-8465C
#4 TAHOE OFFLINE
TAHOE
  • 7,946 Thanks
  • 5,666 posts
Posted August 24, 2015 - 08:28 AM
Sounds like the same setup as my SSI module on the Tecumsehs.
Check out the link in my sig for SSI conversion. I use a small pickup I got from Midwest Super cubs and a magnet glued in the flywheel and it fires a coil. Works pretty well, but motor is always at advance so it will backfire if idled down too quick.
#5 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,436 Thanks
  • 5,757 posts
Posted August 24, 2015 - 12:51 PM
Hard to find these as they are NLA anywhere I looked..  Here's ONE
#6 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 9,843 Thanks
  • 5,945 posts
Posted August 24, 2015 - 01:11 PM
https://www.rcpw.com...21119-2115.html
223.00 isn't terrible if that fixes the problem.  The first one last for nearly 3 decades.
#7 jms180 ONLINE
jms180
  • 1,504 Thanks
  • 1,562 posts
Posted August 25, 2015 - 12:18 PM
Thanks  all. This Kawasaki engine has a pulse coil and charge coil under flywheel. Could the pulse coil be used for an external coil setup?
#8 jms180 ONLINE
jms180
  • 1,504 Thanks
  • 1,562 posts
Posted October 08, 2015 - 08:36 AM
update got the old Gator going again. After much searching found a CDI module under Club Car listing part # 1012520. After cleaning carb it started and runs great. It was a good learning experience on how the cdi ignition system works.  The Kawasaki KF82D-X engine seems to be strong after 28 years
Club Car DS Golf Cart 1984-1989 341cc Ignition Coil 1012520
  • Alc and toomanytoys84 have said thanks
#9 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 9,843 Thanks
  • 5,945 posts
Posted October 08, 2015 - 09:07 AM
looking at that thing I see where this design came from
#10 jms180 ONLINE
jms180
  • 1,504 Thanks
  • 1,562 posts
Posted October 08, 2015 - 11:05 AM
wow i like that scooter. i would love to have that and my friends old Gator
#11 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 9,843 Thanks
  • 5,945 posts
Posted October 08, 2015 - 08:03 PM
I have looked for one of these for years. I have never found even a piece.
#12 toppop52 ONLINE
toppop52
  • 5,233 Thanks
  • 4,749 posts
Posted October 09, 2015 - 06:36 AM
I had a friend with a slightly later 5 wheeler with 2 seats and steering wheel. Those aren't actually Gators, but we all call them that.
