Hahns Hurricane 800
15 replies to this topic
#1 Coventry Plumber OFFLINE
Coventry Plumber
  • 1,086 Thanks
  • 588 posts
Posted August 21, 2015 - 07:38 PM
I picked up a Hahns Hurricane 800 sickle mower today and am wondering if anyone had any information or guidance on how to find out more on it? For instance HP , year or motor brand . I had never heard of one til today. Any info or comments would be appreciated . Thanks in advance.
Northern Tom
  • Alc, Cvans, boyscout862 and 2 others have said thanks
#2 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,914 Thanks
  • 2,451 posts
Posted August 21, 2015 - 08:09 PM
It looks a lot like an early Eclipse Tornado sicklebar mower from the 1950's.
Have you found any nameplates on the engine or mower?
I have some info on Eclipse sickle mowers, but nothing on a Hahn unit.
  • Alc and Coventry Plumber have said thanks
#3 Coventry Plumber OFFLINE
Coventry Plumber
  • 1,086 Thanks
  • 588 posts
Posted August 21, 2015 - 08:17 PM
I haven't looked anywhere on it but the obvious areas so far, and even on the name brand I'm only going on what I was told so not sure on that either. I'm trying to get a handle on what is really is. Thanks. Tom
#4 Coventry Plumber OFFLINE
Coventry Plumber
  • 1,086 Thanks
  • 588 posts
Posted August 21, 2015 - 08:47 PM
I just stumbled upon something that makes me think it's a Hahns eclipse tornado 800 not a hurricane . I had the Wrong storm
#5 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted August 21, 2015 - 09:15 PM
Engine looks close to a Briggs 5s or close to it in the family.
  • Coventry Plumber said thank you
#6 DougT OFFLINE
DougT
    Dog Approved
  • 6,846 Thanks
  • 4,948 posts
Posted August 21, 2015 - 09:23 PM
A briggs for sure and maybe a 5. Didn't the S stand for suction carb? This wouldn't qualify there. The engine tag would be a brass tag on the side of the shroud or an aluminum tag on an air shield around the back of the cylinder.
#7 Bruce Dorsi OFFLINE
Bruce Dorsi
  • 3,914 Thanks
  • 2,451 posts
The Eclipse Tornado would have pre-dated the purchase of the Eclipse Mower Company by Lloyd & Jack Hahn.
The Eclipse Mower Company was located in Prophetstown, Illinois.  .....After the Hahns purchased the company, the mower production was moved to Evansville, Indiana.
I'll look through my manuals for info on the Tornado.
The engine looks to be a B&S 5S or 6S.
#8 KC9KAS OFFLINE
KC9KAS
  • 5,323 Thanks
  • 4,670 posts
Posted August 22, 2015 - 08:27 AM
Fine looking machine....Good find.
#9 Coventry Plumber OFFLINE
Coventry Plumber
  • 1,086 Thanks
  • 588 posts
Posted August 22, 2015 - 10:59 AM
Thanks Bruce. Any help would be appreciated . I cant seem to find out much online.
#10 drbish OFFLINE
drbish
    Collecter
  • 1,555 Thanks
  • 1,357 posts
I just got one of these home today.it looks t h a briggs carb on it .I do not think the nameplate is briggs,maybe Clinton?007.JPG
 This was going to the scrapyard so i had to bring it home
#11 DougT OFFLINE
DougT
    Dog Approved
  • 6,846 Thanks
  • 4,948 posts
Posted August 22, 2015 - 12:03 PM
That engine is a Clinton. The oil fill gives it away. the carb isn't right on it.
  • drbish and Coventry Plumber have said thanks
#12 drbish OFFLINE
drbish
    Collecter
  • 1,555 Thanks
  • 1,357 posts
Posted August 22, 2015 - 04:23 PM
My keyboard has a tendency to not type the letters i mean to type,i thought it was a clinton with the wrong carb,is Convenry plumbers the same
#13 DougT OFFLINE
DougT
    Dog Approved
  • 6,846 Thanks
  • 4,948 posts
Posted August 22, 2015 - 06:29 PM
I don't think so. His first picture shows the base and it looks like a Briggs base with the oil fill down low. A view of the other side would show it. His shroud has the two straps at the top to the head where yours has the full head cover. Does yours have the 2 straps under that cover? I don't think Clinton's did.
  • drbish said thank you
#14 Bruce Dorsi OFFLINE
Bruce Dorsi
  • 3,914 Thanks
  • 2,451 posts
Posted August 22, 2015 - 10:40 PM
Northern Tom
OK, I found some info about your sickle mower.
Yours is an  Eclipse 36"  Tornado 700 Sickle Mower.  ...It is either a Series 1501 or 1502.   ....The 1501 series was a 1947 model, while the 1502 series was a 1948 model.   ...The engine was a B&S Model N with Type number 306168.
The key to identifying your Tornado as a "700" is that is the only model to use the "faceted" tin shield.  ...Earlier & later Tornados had rounded sheetmetal, not faceted.
The Tornados were built from 1941 through 1955.  .....1941-1951 had B&S model N's.  ....1952-1955 had B&S model 6 engines.
Here is a link to all of the info I have for Eclipse Tornado Sickle Mowers:
http://gardentractor...o-sickle-mower/
Edited by Bruce Dorsi, August 23, 2015 - 12:33 AM.
#15 Bruce Dorsi OFFLINE
Bruce Dorsi
  • 3,914 Thanks
  • 2,451 posts
Posted August 22, 2015 - 10:49 PM
If you look at the left side plate (the large casting behind the wheel) of the sickle mower there should be either "SM1" or "SG1" cast into the side plate.
SM1 indicates 1941-1946 production.    .....SG1 indicates 1947-1955 production.
Parts lists for all Tornado models can be found here:
Edited by Bruce Dorsi, August 23, 2015 - 12:34 AM.
  • drbish, Nato77 and Coventry Plumber have said thanks
