Verifying transmission fluid level
1 reply to this topic
#1 AaronH OFFLINE
AaronH
  • 1 posts
Posted April 08, 2011 - 03:41 PM
How do you verify the transmission fluid level on a JD 420? Thanks
#2 olcowhand ONLINE
  • 43,118 Thanks
  • 31,998 posts
Posted April 08, 2011 - 07:52 PM
I believe they are the same as a 318 & 430 as well as others....looking from rear of machine, there should be a clear tube on the right side of main final housing. The clear tube should pass through a metal piece with a square hole. The oil level should be inside this hole in the metal bracket.
  • AaronH said thank you
