Repurposed hoe
9 replies to this topic
#1 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted August 20, 2015 - 02:37 PM
  I got this section of old rotary hoe from a farmer friend and had a couple of days of free time so figured I'd carry out my plan to make it into a lawn aerator. It will be loaded w/ about 300 lbs of large kiln bricks compliments of our local phosphate plant. The rear wheels have springs to hold them in the retracted position and a cheater bar is used to extend them w/ locking pins to hold them in place.
   The ratchet binder will raise the front teeth so it can be rolled over asphalt/ concrete and not dull the teeth. Once hooked to the tractor and ready to roll, the ratchet binder is disconnected from the tongue via a locking pin.
   I pulled it around some this spring w/ just a chain attached and the bricks on it and the teeth penetrated about 1 1/2". I'll see how it works next spring.
                                       Mikehoe 004 (Small).JPG hoe 002 (Small).JPG hoe 003 (Small).JPG hoe 001 (Small).JPG
  • olcowhand, MH81, Alc and 8 others have said thanks
#2 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted August 20, 2015 - 04:24 PM
That thing is so "Mad Max" it's scary.
That being said it looks like something that might do a bit more than aerate, depending on depth and speed.
All it has to do is the job you put it together for.
Nice work
Edited by Chopperhed, August 20, 2015 - 04:25 PM.
#3 shorty OFFLINE
shorty
  • 5,481 Thanks
  • 5,261 posts
Posted August 20, 2015 - 04:36 PM
Looks like it will work good. I have been keeping an eye out for a small section like yours.
#4 KennyP ONLINE
  • 38,361 Thanks
  • 45,927 posts
Posted August 20, 2015 - 06:18 PM
That looks like it could put a hurt on something! Waiting for the results!
#5 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted August 20, 2015 - 07:33 PM
  Too bad you're not closer, there's still 4 sections left.
                                        Mike
  • shorty said thank you
#6 shorty OFFLINE
shorty
  • 5,481 Thanks
  • 5,261 posts
Posted August 20, 2015 - 07:43 PM
                                        Mike
Yeah, shipping could be more than the hoe is worth.
#7 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted August 30, 2015 - 04:20 PM
I have one of those at the farm, mine is a 5' wide tandem like yours.  We have always called them a rotary hoe. It is used to break the top layer of dirt when it gets crusted over so moisture can get to the roots.
#8 UncleWillie OFFLINE
  • 15,670 Thanks
  • 8,761 posts
Posted August 30, 2015 - 05:10 PM
Just don't fall on it, or run over your foot!
#9 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted September 02, 2015 - 12:20 PM
You got that right, I ran over a old metal bucket and it stabbed and mashed the bucket all the way up to the hub, I liked to have never got that thing off.
#10 wolfman OFFLINE
wolfman
  • 2 posts
Posted November 24, 2015 - 02:03 PM
All I can say is watch out ground moles.
