Hydraulic parts help
5 replies to this topic
#1 bryan 110 OFFLINE
bryan 110
  • 220 Thanks
  • 289 posts
Posted August 19, 2015 - 05:04 PM
Who rebuilds hydraulic parts in Wisconsin. And where can I get replacement or rebuild kits for them I have a 446 and we think the contrôlée vealve is going out.
#2 gopher OFFLINE
gopher
  • 750 Thanks
  • 753 posts
Posted August 19, 2015 - 07:25 PM
What symptoms are you having? Usually not much goes wrong with TCV o rings relief valve spring broken.
#3 bryan 110 OFFLINE
bryan 110
  • 220 Thanks
  • 289 posts
Posted August 19, 2015 - 09:09 PM
Well I was able to hold the tractor in place by putting it in forward or reverse and then holding the fenders. And then I played with the Detent ball or what ever you call it and it has more power as in it will pull m e around but still not the power that it should.
I asked on another forum and someone said it was in the gear box so I opened that and everything looks good. The hi and lo feels the same as our low hour 220 and out 155. I am just guessing it's the tcv but I could be wrong. Like I said above I just played with it a little and it gained a little power but I better the 220 could drag it around.
#4 bryan 110 OFFLINE
bryan 110
  • 220 Thanks
  • 289 posts
Posted August 22, 2015 - 09:34 PM
No luck with it yet I changed the hydrive oil still nothing
Dose anyone have a break down of the tcv for a 72 446
#5 bryan 110 OFFLINE
bryan 110
  • 220 Thanks
  • 289 posts
Posted August 22, 2015 - 11:09 PM
After reading the stuff you sent me gopher I think I need to re look at the relief I had it out today wad it only had the acorn nut and screw. I'll tear it down again to morrow and see if it's missing parts?
Ps after today's tear down it looks like someone was inside the tcv but could be wrong
And if that checks out she's going to rehab at the case dealer.
#6 gopher OFFLINE
gopher
  • 750 Thanks
  • 753 posts
Posted August 22, 2015 - 11:29 PM
Can you get the lift circuit to squaw the relieve valve?  could be pump going bad. You might check the spring length if broke and po took part of it out that would keep the pressure down.
