Mini Dozer - $1500 (Mansfield, CT)
4 replies to this topic
#1 boyscout862 ONLINE
  • 13,548 Thanks
  • 9,427 posts
Posted August 18, 2015 - 12:45 PM
Cute but not for me. Maybe one of you. Good Luck, Rick
http://newlondon.cra...5178687521.html
Mini Dozer - $1500 (Mansfield)
00M0M_3sLrUYLerCB_50x50c.jpg01212_5znKfjQfL64_50x50c.jpg00J0J_7hNV451jQUI_50x50c.jpg01313_lK8FXgoT6GY_50x50c.jpg00M0M_4IoeRLW1Gf4_50x50c.jpg00g0g_hYbE6h5QubS_50x50c.jpg
Mini Dozer / bulldozer. Has Struck Corp. steel tracks, sprockets and axles. Bolens STG 125 tractor was used as the engine and trans-axle. 3 to 1 gear reduction on final drive. 5 speeds forward and 1 reverse. Pressure up and down on blade. Entire unit weighs around 700 lbs. it will easily push triple that weight. It's 4' wide and 6' long. Will fit in the bed of a truck. Runs good. Needs a battery and paint. No lowballers. I don't need the money. No offers without seeing it. Only selling because I don't use it very often. I can deliver locally for a small fee. Please do not call after 7 PM. Thanks
  • Traill95 said thank you
#2 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted August 18, 2015 - 01:32 PM
Cute, but mines bigger :)
#3 Diesel1050 OFFLINE
Diesel1050
    Diesel Nut!
  • 379 Thanks
  • 418 posts
Posted August 18, 2015 - 05:46 PM
Not worth it since it has a lawn tractor axle......highly doubt that will hold up!
#4 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted August 18, 2015 - 09:41 PM
That was quite possibly one of the stupidest things I've ever posted on the internet.
My apologies, the moment just come on me to do it.
Its a neat little tractor. Yes the driveline is weak, but the Struck driveline is weak too.
If I had it I'd work it,
Wouldn't buy it though.
#5 grnlark OFFLINE
grnlark
  • 338 Thanks
  • 374 posts
Posted August 19, 2015 - 06:11 AM
I saw a guy dig an entire foundation hole for a garage once with a struck. It was a long slow process but moved the dirt like a champ.
