09JC9848 Blade Parts Info Needed
24 replies to this topic
#1 KennyP ONLINE
  • 40,219 Thanks
  • 46,806 posts
Posted April 08, 2011 - 08:04 AM
I need to make some missing parts for my blade. I would like to have the dimensions of item #32 in the attached parts breakdown. I know diameter of piece, but where the location and length of the piece for the angle rod hooks to. Handle height would be nice also. Any info will be much appreciated.
I marked what I do not have, most will be easy to make. The length of the angle control rod would be another plus, though I plan to make it adjustable. Thanks.
#2 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted April 08, 2011 - 08:30 AM
I have a aftermarket blade on my fords so I can't help. But good luck in finding the info you need.
#3 KennyP ONLINE
  • 40,219 Thanks
  • 46,806 posts
Posted April 08, 2011 - 08:45 AM
I have had this question over at MTF for months, and no one has come up with anything yet. I think several different models had the same handle on them. Maybe there is light at the end of the tunnel.
#4 KennyP ONLINE
  • 40,219 Thanks
  • 46,806 posts
Posted April 11, 2011 - 03:24 AM
Fooled with the blade parts yesterday. Got items 32 and 39 built. Have to wait on the other two until I mount the blade again.
#5 Buck OFFLINE
Buck
  • 36 Thanks
  • 116 posts
Posted August 09, 2011 - 08:00 PM
Dont know if you will see this but how did you make out with it? I was going to take a pic of mine and send it to you. But now you have me worried because mine looks like yours and I have no handle as well. The guy I bought it from told me that it hooks up to the hdro lift. I have not messed with it but is this sound right?
#6 Buck OFFLINE
Buck
  • 36 Thanks
  • 116 posts
Posted August 09, 2011 - 08:02 PM
ps. I thought the angle was a bolt that was moved by hand.
#7 KennyP ONLINE
  • 40,219 Thanks
  • 46,806 posts
Posted August 10, 2011 - 03:22 AM
Haven't messed with this any more, Buck. It does lift with the hydraulics, but the angle is adjusted by hand (unless you have a cyl. on the blade for angle adj.). I need to build item #'s 34 & 37, but need the blade on the tractor to do this so the handle will clear the left foot rest. I can get some dimensions of the other parts if needed.
#8 firstgen89sho OFFLINE
firstgen89sho
  • 82 Thanks
  • 90 posts
Posted August 11, 2011 - 08:22 AM
I'll be watching this one as well, as the blade that I got with my tractor, was missing the exact same parts... and one less trip spring..... lol
#9 Buck OFFLINE
Buck
  • 36 Thanks
  • 116 posts
Posted August 11, 2011 - 01:22 PM
Yea so Kenny make up three of everthing so we can buy it from you! LOL!
#10 KennyP ONLINE
  • 40,219 Thanks
  • 46,806 posts
Posted August 11, 2011 - 03:35 PM
Since I haven't put the blade back on yet, I am unsure if the parts I made will work right. If they do, I'll get some pics and measurements.
#11 Buck OFFLINE
Buck
  • 36 Thanks
  • 116 posts
Posted August 25, 2011 - 07:36 PM
Kenny, winter is coming! how are our plow parts coming along? LOL!
#12 KennyP ONLINE
  • 40,219 Thanks
  • 46,806 posts
Posted August 26, 2011 - 03:52 AM
Still working for at least another week yet. Maybe Labor day weekend I can get it out. Just too much to do on weekends to get to that. Hang in there, though. Once done with the remodel, I'll hook the blade up and get you some pics of what I have. I only have one trip spring also.
#13 KennyP ONLINE
  • 40,219 Thanks
  • 46,806 posts
Posted September 08, 2011 - 05:59 PM
Hey, Buck. Put the blade on the Ford this evening. I wanted to have some time to think about it over night. I have noticed one thing so far. We'll work off this pic.
Part #32 is shown with the bar, #39, to hook to pointed forward. When you moved the lever back, it would have interference with the blade lock mechanism, #26. I have mine pointed down which leaves it clear of any other mechanisms. If you point it up, you will have to put a bend in the angle bar to clear the steering tie rods. Plus, having it run straight should make it stronger.
Tomorrow, I hope to complete the handle and rod to unlock for rotation.
#14 KennyP ONLINE
  • 40,219 Thanks
  • 46,806 posts
Posted September 08, 2011 - 06:05 PM
Something I forgot to add. The 'stock lift' only raises the blade a couple inches off the ground. I stuck a piece of 3/4 plywood between the mower lift bar and the bottom of the blade. This gave me about 4-5" of lift off the ground. Plus, I still have plenty to go below grade. May have to add something to the bottom of the blade in that area for this. I'll take pics tomorrow.
#15 Buck OFFLINE
Buck
  • 36 Thanks
  • 116 posts
Posted September 08, 2011 - 07:52 PM
Hi Kenny,
My plow is sitting at the shop and I was going to bring it home tonight because I want to see how this set up is going to work. I was looking at your pic and from # 21 to 29 is missing on mine. Cant tell what it does from pic. Kinda funny how I was going to get on this today and saw that you posted this today! Thanks for posting! I took the deck off for the week as I was "logging" trees from our tropical breeze we had last week!
ps. Are you saying the 4-5" raise would be better? I would think so for plowing snow, not getting hung up.
Edited by Buck, September 08, 2011 - 07:58 PM.
