pulling tires with fluid
13 replies to this topic
#1 collinmf12 OFFLINE
collinmf12
  • 114 Thanks
  • 197 posts
Posted August 17, 2015 - 01:58 PM
I have a stock Massey 10 puller and to make more weight i was going to fill the tires with either antifreeze or washer fluid. But I heard from other people that it kills your power and they don't dig as well and that filling the tire is a bad decision. What are your thoughts? Any feed back will be helpful.
               Thanks,
                     Collin
  • CharlesDes said thank you
#2 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted August 17, 2015 - 02:10 PM
Tell us a little bit about the class/classes you plan on pulling first
  • collinmf12 said thank you
#3 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted August 17, 2015 - 03:01 PM
I was at a pull on Saturday with a buddy of mine and all I saw used were weights, as a side note he had an extra tractor along so I got to pull for the first time ever, my tractor had no extra weight beside my fat butt lol.  the tractor with me on it (Cub Cadet 100) weighed in at 950lb, which worked out ok since I was only pulling in the 1050 (light) class.
#4 wilberj ONLINE
wilberj
  • 4,990 Thanks
  • 5,589 posts
Posted August 17, 2015 - 03:12 PM
Takes more power to tern filled tires.  That is from a friend of mine who about won every pull in his class all over the state of Michigan.
#5 chieffan ONLINE
  • 9,598 Thanks
  • 6,424 posts
Posted August 17, 2015 - 03:31 PM
I don't see where it would make any difference on the amount of power it would take to turn a wheel.  It will take XX hp to turn 2 - 300 lb wheels regardless of how the weight is on them.  300 lbs is 300 lbs.  Once turning it would be like a fly wheels and help keep the momentum going.
#6 collinmf12 OFFLINE
collinmf12
  • 114 Thanks
  • 197 posts
Posted August 17, 2015 - 03:43 PM
1000 pound factory stock 16hp
#7 collinmf12 OFFLINE
collinmf12
  • 114 Thanks
  • 197 posts
Posted August 17, 2015 - 03:44 PM
thanks everyone for the help
#8 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted August 17, 2015 - 05:52 PM
OkaySo how about the tires and rims? What size tires and what kind of rims? steel or aluminum pulling rims?
#9 skyrydr2 OFFLINE
  • 3,870 Thanks
  • 3,403 posts
Posted August 17, 2015 - 08:57 PM
In a stock class rotating mass is debatable , one tractor we run in stock , has 160# of weight on the wheels and it pulls really good!! Its a craftsman GT 18 and it hangs right there with the cub we pull with.
  • DaveBb said thank you
#10 MH81 OFFLINE
Posted August 17, 2015 - 10:37 PM
Around here, they do not allow filled tires because of track contamination if one bursts.
#11 collinmf12 OFFLINE
collinmf12
  • 114 Thanks
  • 197 posts
Posted August 18, 2015 - 11:46 AM
goodyear ag tires on steel rims the size is 23x10.5-12
  • Dieselcubmike said thank you
#12 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted August 18, 2015 - 05:08 PM
Since you already have steel wheels there is no need to run filled tires. What this does is helps dig a hole faster. What you want to focus on is weight balance. Make under frame weight bar in front of the transmission  to hang weights on and the rear weight and front weight as well.
  • collinmf12 and DaveBb have said thanks
#13 DaveBb OFFLINE
DaveBb
  • 405 Thanks
  • 173 posts
Posted August 19, 2015 - 07:20 AM
Agree with Mike on this. Balance is everything. The guys that pull the best at least around here catch a bit of air towards the end of the track. The guys doing huge wheelies don't go far and end up being all over the track with little control. You can count on about a $1.00/Lb for weights of any kind. I made a hanger that bolts to the frame with a removable 1 inch bar. I can hang 340 under there. Also some off the back behind seat.
Edited by Saxist, August 19, 2015 - 07:28 AM.
#14 collinmf12 OFFLINE
collinmf12
  • 114 Thanks
  • 197 posts
Posted August 19, 2015 - 09:37 AM
thanks for all your help
