Got an LK!
170 replies to this topic
#151 KennyP ONLINE
  • 50026 Thanks
  • 52252 posts
Posted August 04, 2017 - 11:06 AM
Looking good.  You could run a piece of flat iron from the one recoil mounting screw up to the bolt at the front of the fuel tank to act as a brace - just a suggestion.
Thinking along those lines. Or over the other side to the shroud bolt. Might be unsightly, but would stiffen things. Gotta get the little thing started and see what it does right now.
  • logmillingman said thank you
#152 Austen OFFLINE
Austen
  • 3426 Thanks
  • 1393 posts
Posted August 04, 2017 - 11:10 AM
Nice job on the steering wheel, that is a huge improvement. :thumbs:
#153 KennyP ONLINE
  • 50026 Thanks
  • 52252 posts
Posted August 04, 2017 - 02:19 PM
Well, I pulled the carb bowl and found a mess! Gonna need some parts. @ Bolens 1000, if you have a a needle,seat and bowl gasket for these, send me a PM.
  • Bolens 1000 said thank you
#154 Bolens 1000 ONLINE
  • 17293 Thanks
  • 18793 posts
Posted August 04, 2017 - 04:44 PM
Will do have everything here instock
#155 KennyP ONLINE
  • 50026 Thanks
  • 52252 posts
Posted August 09, 2017 - 04:09 PM
Got the new carb kit for Bolens 1000. Put it together and set the float like the manual says and it floods big time. Reset the float to a lower setting and the needle won't unseat (ie, no gas in the bowl). Been fighting with it all afternoon. I'm about ready to use a 4 lb. sledge to adjust it permanently! Either floods or the needle sticks closed! No in between!
  • Bolens 1000, shorty and logmillingman have said thanks
#156 Bolens 1000 ONLINE
  • 17293 Thanks
  • 18793 posts
Posted August 09, 2017 - 08:23 PM
Is this the old metal or new plastic style?
Did you put that little white seat in the right way with the lip edge facing in towards the hole?
#157 KennyP ONLINE
  • 50026 Thanks
  • 52252 posts
Posted August 10, 2017 - 05:05 AM
The seat is in the right way, It's the old brass float, not full of fuel.
#158 KennyP ONLINE
  • 50026 Thanks
  • 52252 posts
Posted August 10, 2017 - 02:10 PM
Guess a 4 lb. sledge is the right way to adjust it!
  • holdenboy1960 and logmillingman have said thanks
#159 KennyP ONLINE
  • 50026 Thanks
  • 52252 posts
Posted August 11, 2017 - 05:22 AM
I'm letting this set for a while again! Maybe the fresh fuel will help it. Just frustrated with it!
#160 holdenboy1960 OFFLINE
holdenboy1960
  • 1851 Thanks
  • 985 posts
Posted August 11, 2017 - 05:36 AM
looks good there and still in reasonable condition too , the articulated machines have always intrigued me
maybe one day
Shane
#161 KennyP ONLINE
  • 50026 Thanks
  • 52252 posts
Posted August 11, 2017 - 05:47 AM
maybe one day
Shane
It's fun to drive/mow with! Hope it will quit this issue soon.
#162 logmillingman ONLINE
logmillingman
  • 2164 Thanks
  • 896 posts
Posted August 11, 2017 - 06:40 AM
I was having the same problem with my tech. carb I had to fiddle with the spring and the float shaft. I don't know why the needle is sticking, I would try removing the float and needle then take the needle with your fingers and turn it back and forth like you were lapping a valve up against the seat, that may help it not to stick together, just a thought but maybe worth a try.
Edited by logmillingman, August 11, 2017 - 06:42 AM.
  • KennyP and WrenchinOnIt have said thanks
#163 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 4971 Thanks
  • 2859 posts
Posted August 11, 2017 - 07:21 AM
Here's something I learned from much experience with Tecumseh float valves having the soft seat and metal needle:
Tecumseh always recommended installing the soft seat with the sharp edge of the seat going into the carb body first.  ...This left the tapered opening facing the point of the metal needle.
The tapered point of the needle would wedge in the tapered portion of the seat, causing the needle to stick closed.
After fighting this on many occasions, I began installing the soft seats in the opposite direction, so the tapered portion went into the carb body first.
The point of the needle now makes a "line" contact against the soft seat, which seals, but does not wedge together.
Do not use a screwdriver to push the seat into place, as it will damage the seat.  ....I used a B&S fiber point plunger or a cut-off B&S air cleaner screw, but any flat-bottomed rod of the correct diameter will properly install the seat.
This method served me well for many years in our shop.  ...I hope it works for you, too!
Edited by Bruce Dorsi, August 11, 2017 - 07:25 AM.
  • KennyP, WrenchinOnIt, TomLGT195 and 1 other said thanks
#164 KennyP ONLINE
  • 50026 Thanks
  • 52252 posts
Posted August 11, 2017 - 07:30 AM
I used a 5/32" pin punch to put it in, Bruce. May take the carb back off and look into what you are saying.
#165 Bruce Dorsi OFFLINE
Bruce Dorsi
  • 4971 Thanks
  • 2859 posts
Posted August 11, 2017 - 07:41 AM
Kenny:  The best way to remove the seat for re-use is to blow it out with compressed air applied to the fuel inlet elbow.
Be sure to cover it with a rag to prevent launching the seat into unknown territory.
In an earlier post, you questioned the small screw under the plate over the carb.  ...This screw is used to adjust the top speed (rpm) to increase or limit the rpms at full throttle. ...It has no effect on fuel mixture.
  • Bolens 1000, KennyP, WrenchinOnIt and 1 other said thanks
