bolens 1050 p.t.o and drive belts
9 replies to this topic
#1 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted April 07, 2011 - 09:18 PM
i was woundering where i can buy the blue kevlar belts for my 1050?
#2 Bolens 1000 OFFLINE
  • 17296 Thanks
  • 18794 posts
Posted April 07, 2011 - 09:32 PM
Funny you ask that I was actually in the process of trying to locate some affordable ones to stock up on. You will need them in a matched set.
If you dont need them right away let me see what I can come up with by sometime next week. I'm working with a dealer who may have a close replacement for the 42.5'' PTO belts which would be nice
#3 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted April 08, 2011 - 05:18 AM
well i would like to have them for pa plow day on the 16th. i have the motor out of the 1050 because the rear crank case seal started leaking. so while the motor is out it will be easy to do the belts. sams bolens charges about 80 for both sets but he says there OEM but i thought the blue ones would be alot better. correct me if i am wrong
#4 NUTNDUN OFFLINE
  • 10430 Thanks
  • 15622 posts
Posted April 08, 2011 - 05:36 AM
If you can find a place that sells Gates belts, I can't remember the style name, like power rated or something but they are green kevlar reinforced belts. I think they were around $20 a piece.
#5 Bolens 1000 OFFLINE
  • 17296 Thanks
  • 18794 posts
Posted April 08, 2011 - 07:01 AM
Yeah $80 is a bit high
Bhts has OEM for sale for around $50-60 I believe.
I have been using the kevlar belts on some of my Bolens and they are holding up great. They still look new after almost a year of service.
I have had bad experiences with the gates belts, but other people seem to use them without problems. I dont know if you would be able to get a matched set of gates at your local store though.
"In theory" Since the belts run together in the pulley you need them to be the exact size and cut from the same belt lot.
  • DGS345 said thank you
#6 Bolens 1000 OFFLINE
  • 17296 Thanks
  • 18794 posts
Posted April 08, 2011 - 07:06 AM
By the looks of it now I can get the matched sets for the drive belts for around $35 I believe.
I'm guessing the PTO belts would be somewhere around there as well.
#7 DGS345 OFFLINE
DGS345
  • 17 Thanks
  • 348 posts
Posted April 09, 2011 - 09:37 AM
let me know if you can get these belts. I want to change all 4 of mine
#8 Bolens 1000 OFFLINE
  • 17296 Thanks
  • 18794 posts
Posted April 09, 2011 - 10:01 AM
I ordered a pair of drive and PTO belts that should be here by Thursday.
I still didnt pay for them yet so once they are in I will know an exact price. I was able to get a close match to the PTO belts.
I'll let you know once they come in.
#9 EricFromPa ONLINE
EricFromPa
    Fixer of Broken junk
  • 6355 Thanks
  • 4420 posts
Posted April 09, 2011 - 11:48 AM
Tractor Supply has Husky or Pix A-Section (Husky replacement) Kevlar Blue belts for $9.99 each.I used a 43 inch belt for the PTO belts and a 34 inch for the Drive belts.
They are usually from the same Lot number at TSC.
I replaced the idler pulley for the PTO with a new one from TSC as well.The new ones are a tad bigger so it worked out Very well.
PIX A-Section Kevlar® Belt, 1/2 in. x 43 in. - 4460838 | Tractor Supply Company
PIX A-Section Kevlar® Belt, 1/2 in. x 34 in. - 4460749 | Tractor Supply Company
All belts from TSC have a 1 year replacement warranty.
You can use a 42 inch belt for the PTO but it might not fully disengage the PTO.It all depends if your spring under the Cover plate is rusty and weak like mine was.
And even though they say they're 1/2 inch wide they are actually a tiny bit wider because of the Blue wrap they put on them.
So they'll sit a tad higher in the pulleys till they get broken in.
Edited by EricFromPa, April 09, 2011 - 11:56 AM.
#10 Bolens 1000 OFFLINE
  • 17296 Thanks
  • 18794 posts
Posted April 13, 2011 - 08:04 PM
Belts are in
If anyone is interested PM me for more info.....
