Field testing today. Potatoe plow
9 replies to this topic
#1 propane1 ONLINE
propane1
  • 9,471 Thanks
  • 4,403 posts
Posted August 15, 2015 - 05:10 AM
Going to try out my potatoe plow today. May need some adjustments before paint. It maybe to small. May need extensions or fingers added. Noel
  • Alc, JD DANNELS, KennyP and 6 others have said thanks
#2 Alc ONLINE
  • 7,246 Thanks
  • 7,589 posts
Posted August 15, 2015 - 05:29 AM
Looking forward to seeing how you make out , good luck !
  • boyscout862 and propane1 have said thanks
#3 KennyP ONLINE
  • 40,954 Thanks
  • 47,135 posts
Posted August 15, 2015 - 06:05 AM
Hope it worked!
  • propane1 said thank you
#4 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1,179 Thanks
  • 697 posts
Posted August 15, 2015 - 07:52 AM
I hope it works for you. I will be digging mine by hand in a few weeks.
#5 KC9KAS ONLINE
KC9KAS
  • 5,469 Thanks
  • 4,725 posts
Posted August 15, 2015 - 09:07 AM
I bet that plow will work just fine as long as you get it deep enough that you get under the potatoes and not cut them up.
I see the mower deck still on....you going to mow the hills down as you plow the taters :poke:
#6 propane1 ONLINE
propane1
  • 9,471 Thanks
  • 4,403 posts
Posted August 15, 2015 - 09:16 AM
Hehe. One nevers knows what ideas a fella may come up with. Noel.
#7 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted August 15, 2015 - 09:34 AM
Good luck with that. I dig enough hills for the table early in the season. But if I had to dig the whole crop with a fork I would not grow near as many. I had enough years ago when the ground was so hard you would bend fork tines.
#8 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted August 15, 2015 - 09:40 AM
That looks good Noel. You might want to add a cage on the back of the shovel to let the dirt to fall out.
Dug mine yesterday and dad was saying I needed a cage bed behind and a shaker on mine.
I could power a shaker with my PTO.
Somewhere I saw a guy mount a 12 volt motor with an elliptical weight on it to shake the bed, since he did not have a rear PTO.
  • Alc and propane1 have said thanks
#9 propane1 ONLINE
propane1
  • 9,471 Thanks
  • 4,403 posts
Posted August 15, 2015 - 01:17 PM
Yes, I have bent fork times too. Noel.
#10 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1,179 Thanks
  • 697 posts
Posted August 15, 2015 - 04:30 PM
I think you would bend a fork in my garden most years JD. I use a shovel to dig them.
