need reverse parts....575104
8 replies to this topic
#1 stubbysteve OFFLINE
stubbysteve
  • 54 Thanks
  • 107 posts
Posted August 13, 2015 - 01:55 AM
Db part number 575pa617 #25 in manual. It is called a "finger L H"
Db part number 575pa622 #43 in manual. It is called "reverse bracket and finger"
I have the plates but no fingers on them. And I believe my "L H" bracket some one made but not sure.
Here is a picture of what I have. If someone has these pieces and could measure the fingers that would be appreciated.
#43 on left #25 on right
#2 IWLBCNU OFFLINE
IWLBCNU
  • 120 Thanks
  • 158 posts
Posted August 13, 2015 - 07:04 AM
Both plates look correct, it is common for them to break, I have just bought solid rod from tractor supply and welded it back in the spots before.
#3 stubbysteve OFFLINE
stubbysteve
  • 54 Thanks
  • 107 posts
Posted August 13, 2015 - 08:43 AM
That would be fine if I knew how long they were. Do u remember by chance and what diameter?
#4 dblover OFFLINE
dblover
  • 266 Thanks
  • 160 posts
Posted August 16, 2015 - 01:34 PM
Rods are 5/15" o.d. and 6 5/16" long with 1/8" overhang where welded to frame bracket. The length measurement is not critcal - leave extra in case you slide hubs out further. Rods run parallel to axle shafts.
Edited by dblover, August 16, 2015 - 01:39 PM.
#5 stubbysteve OFFLINE
stubbysteve
  • 54 Thanks
  • 107 posts
Posted August 16, 2015 - 01:47 PM
Cool thanks. So the pin goes all the way through the friction blocks and springs correct?
#6 stubbysteve OFFLINE
stubbysteve
  • 54 Thanks
  • 107 posts
Posted August 16, 2015 - 02:35 PM
Also not to sound stupid but thes go on after the handle bars go on correct? I cant see the handle plate in the picture. Again thanks a lot.
#7 dblover OFFLINE
dblover
  • 266 Thanks
  • 160 posts
Posted August 16, 2015 - 03:36 PM
The hubs/wheels may be slid in or out to avoid crops when cultivating or more stability. As a result, the reverse rods to the hubs merely pass through to allow the width adjustment for the hubs. Nothing complicated here. Don't over think this.
#8 dblover OFFLINE
dblover
  • 266 Thanks
  • 160 posts
Posted August 16, 2015 - 03:40 PM
Make it like what the pics show. Brackets are bolted on last on top of handle bars..
#9 stubbysteve OFFLINE
stubbysteve
  • 54 Thanks
  • 107 posts
Cool thanks.
