Wanted
8 to 12.5 Hp Briggs Vertical Shaft Engine near NE Ohio
engine cheap briggs
3 replies to this topic
#1 rugbywarrior89 OFFLINE
rugbywarrior89
  • 33 Thanks
  • 39 posts
Posted August 11, 2015 - 11:25 PM
I've got a crappy old 1997 lawn machine that I have been using when I work on my bolens.  Recently, the engine blew up (lost compression and won't start.  Assuming it's the crankshaft)  but I would like to keep it as a spare.  I'm hoping somebody has an engine lying around cheap that I could get (around $50).  I have all the parts off the old 12.5 28Vxxx engine.  I don't care if it's a smaller (or biggger) engine than original, it's only a 38" deck and a spare tractor.
#2 boyscout862 ONLINE
  • 12,543 Thanks
  • 9,041 posts
Posted August 12, 2015 - 05:26 AM
Before you give up on that engine, check that a valve spring keep didn't just come off. It has happened to me. When I figured it out it was less than an hour to fix. Good Luck, Rick
  • limebuzz and TomLGT195 have said thanks
#3 limebuzz ONLINE
limebuzz
  • 965 Thanks
  • 955 posts
Posted August 18, 2015 - 02:45 PM
Yup, I've also had one that had a bent push rod.
#4 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted August 31, 2015 - 04:50 PM
I'm in Florida, don't know about shipping etc. but have an older 11 hp vertical that never skips a beat.  Posted in the parts for sale section.
Also tagged with one or more of these keywords: wanted, engine, cheap, briggs
