Need new blades for 36" mower deck
12 replies to this topic
#1 Buck Tales OFFLINE
Buck Tales
  • 187 Thanks
  • 122 posts
Posted August 11, 2015 - 07:02 PM
My mower deck doesn't have any numbers on it but it is a 36" deck with the 90 degree gear boxes and live shaft. I have looked up a couple places and came up with 2 different part numbers #5047H and #6768H as blades. Mine looks like a 917.99620 deck except that the wheels are on more of a bracket rather than molded part of deck. Does anyone know of anyplace to get blades or someone that is remanufacturing blades? I'll get a couple of pictures of deck and post them also.
#2 Buck Tales OFFLINE
Buck Tales
  • 187 Thanks
  • 122 posts
Posted August 11, 2015 - 07:10 PM
OK, here are some pictures of the deck in question. Any help would be great.
#3 craftsmanmowerfreak ONLINE
craftsmanmowerfreak
  • 288 Thanks
  • 231 posts
Posted August 11, 2015 - 09:47 PM
when i last looked them up they was no longer available
#4 Buck Tales OFFLINE
Buck Tales
  • 187 Thanks
  • 122 posts
Posted August 11, 2015 - 09:55 PM
I know, thats what the Sears site says when I looked them up too. I'm hoping somewhere somebody might know of after market blades that will work.
#5 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,135 Thanks
  • 4,896 posts
Posted August 11, 2015 - 10:05 PM
Take the blades off and take them to your local auto parts store.  Tell them to get out the Prime Line book.  There are pictures of many, many blades of all different lengths.  Something should match up.
#6 craftsmanmowerfreak ONLINE
craftsmanmowerfreak
  • 288 Thanks
  • 231 posts
Posted August 11, 2015 - 10:31 PM
any autoparts store?
#7 Bolens 1000 ONLINE
  • 14,922 Thanks
  • 18,112 posts
Posted August 12, 2015 - 07:20 AM
The auto stores will charge you out the nose and then you get tacked on about $14 freight
I can likely get you replacements. let me know the hole size and length of the blade (Measure diagonally tip to tip)
Looks like there's only one hole in the blade correct? Those are easy to interchange!
  • Bud W said thank you
#8 Buck Tales OFFLINE
Buck Tales
  • 187 Thanks
  • 122 posts
Posted August 12, 2015 - 04:42 PM
Yeah 1 hole but the sides are flat to fit the adapter. The adapter keeps the blades from hitting each other when spinning. The 90 degree gear boxes are set up to be timed so the blades are horizontal and vertical of each other. My fear of putting a round hole blade on and tightening up on it is that if 1 comes loose the blades could hit each other and damage the gearboxes. Not an easy answer to this one for sure. I'll remove a blade tomorrow and take a close up picture for you.
#9 Buck Tales OFFLINE
Buck Tales
  • 187 Thanks
  • 122 posts
Posted August 14, 2015 - 03:27 PM
I took the blade off and took some shots of the components. As you can see there is a blade adapter which has the blade hole and the shaft hole both. The blade is 19.25" long and 2.5" wide.
Brian I got a picture of the extra blade adapter with the part number from years ago when I was able to get them. Possibly you could see if they are still available for me? Thanks
#10 Wendell Rider OFFLINE
Wendell Rider
  • 7 Thanks
  • 32 posts
Posted September 20, 2015 - 08:51 AM
If you find any new ones let me know, I'll buy a set too. The blades with that type of hole are called either "D" or "Double D" I can't remember which.
Thanks.
#11 drbish ONLINE
drbish
    Collecter
  • 1,555 Thanks
  • 1,358 posts
Posted September 20, 2015 - 11:40 AM
The old rotary number for a replacement is 17-423
#12 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted October 06, 2015 - 10:22 PM
Same ones I need too. Autopart store didn't have them available. Looks like we have to grind them........ unless we upgrade mower deck?
#13 Bolens 1000 ONLINE
  • 14,922 Thanks
  • 18,112 posts
Posted October 07, 2015 - 08:00 AM
Washer still available for $5.10 but both 36'' and the 38'' Blades are NLA  unfortunately
