Ford 1500 w King Cutter DISC
9 replies to this topic
#1 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted August 11, 2015 - 02:50 PM
Had the disc mounted this afternoon to disc down the raised beds where I had the onions, garlic and shallots planted. So thought it was a good time to post a picture.
The disc is 6 1/2 ft wide and would have done better if it was drier. We got 2 1/2vinches of rain Sunday morning.
This disc is as big as I would want, it pulls well but is heavy enough that the front wheels are light
and will skid turning with it lifted, I use the brakes on turns for that reason.
  • Alc, KennyP, shorty and 2 others have said thanks
#2 shorty ONLINE
shorty
  • 5,774 Thanks
  • 5,390 posts
Posted August 11, 2015 - 03:02 PM
Looks good JD. Makes me think that a bigger tractor like yours sure would be nice.
  • JD DANNELS said thank you
#3 propane1 ONLINE
propane1
  • 9,145 Thanks
  • 4,281 posts
Posted August 11, 2015 - 03:51 PM
This is what I use to do disking. Works great. I put weight on the front set of disks,    Noel
  • JD DANNELS and KennyP have said thanks
#4 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted August 11, 2015 - 04:29 PM
I do really enjoy it. It burns less fuel per hour than my garden tractors.
I have 9 Acres and the longer wheelbase and taller tires makes for a smoother ride over rough ground.
  • Alc and shorty have said thanks
#5 propane1 ONLINE
propane1
  • 9,145 Thanks
  • 4,281 posts
Posted August 11, 2015 - 04:41 PM
Good points. My area not that big. I use my ferguson farm tractor for cutting grass now. Six foot rear discharge finish mower. Much better ride. Noel.
Oops, upside down again.
#6 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted August 11, 2015 - 07:12 PM
My Ford is rated for the same size implements as a N series Ford. But is diesel.
I have mowed my lawn with the 5 ft brush cutter and it does not look bad.
I M looking for a finish mower and with that I would mow all 9 acres and only use the brush cutter when things got rough.
Incidentally the Cockle Burrs in that picture have been pulled since I posted the picture.
Edited by JD DANNELS, August 11, 2015 - 07:17 PM.
  • Alc and propane1 have said thanks
#7 propane1 ONLINE
propane1
  • 9,145 Thanks
  • 4,281 posts
Posted August 11, 2015 - 08:20 PM
Nine acres is a lot more than mine, I cut about two and a half , but two houses, trees, gardens and other stuff to go around takes me about 5 to 6 hours to do by myself, with weed whacking included. But I enjoy it. So your ford 1500 tractor would be about 20/22 hp with a catorgory one, three point hitch ? Noel
And the six foot finish mower does just as good of job of cutting grass, as any of my garden or lawn tractors.
Edited by propane1, August 11, 2015 - 08:23 PM.
#8 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted August 11, 2015 - 08:24 PM
Are you using an IPad? I used to to do that till someone told to rember to keep the camera. Eye to the left.
  • propane1 said thank you
#9 propane1 ONLINE
propane1
  • 9,145 Thanks
  • 4,281 posts
Posted August 11, 2015 - 08:35 PM
That picture was takin before some one told me that. I now try to remember to turn the iPhone, is what I think I have, upside down and use the bottom buttons to take the picture. So the camera would then be on the top left facing the thing you are going to take a picture of. Would that be right. Noel.
#10 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted August 11, 2015 - 09:22 PM
Yes the Ford is rated at 20 hp, 17 at the PTO. 2 cyl diesel. Weighs just over 2000 lbs. Yes it is cat1. It has 9.5x 24 tires, I have two 70 lb wheel weights on each wheel. And 3 -33 lb weights out front. The 48 inch gear drive tiller calls for 25 PTO hp, but it pulls it ok. That is the one tool,where I wish I had more power. I have the tiller,disc,landscape rake,rear blade,King Cutter pan scraper, and 5 ft brush cutter. Oh I forgot the middlebuster and Dad aNd I made a hiller/bedder, I like raised beds and everything but the corn and potatoes are planted on them.
I have 3 5ft sections of an old horse drawn spike harrow need to make a frame to lift them with the 3 point. Right now I just drag them.
My rear wheels are set at 48 inches on center, so I would only pull two sections.
I found them standing against the back fence, after I bought this place.
Before I got the Ford I pulled one section with the 318.
Edited by JD DANNELS, August 11, 2015 - 09:27 PM.
  • Alc, Cvans and propane1 have said thanks
