Do you know what it is?
20 replies to this topic
#1 Cvans ONLINE
  • 7,119 Thanks
  • 6,304 posts
Posted August 10, 2015 - 08:26 PM
This showed up while putting a new porch on the house. No one seems to know for sure what it is. It's cast iron and appears to be old.
  • hamman said thank you
#2 Cat385B ONLINE
    HAZMAT CAT
  • 14,279 Thanks
  • 10,116 posts
Posted August 10, 2015 - 08:53 PM
Door or window latch.
  • hamman and Cvans have said thanks
#3 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,279 Thanks
  • 4,513 posts
Posted August 10, 2015 - 08:55 PM
That looks like a hook that would be used to hold a weight in a old window sash.
  • hamman, Cvans, Team_Green and 1 other said thanks
#4 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted August 10, 2015 - 09:17 PM
that would be my guess! Though I have never seen one quite like that, it could be the sash weight?
Most I have seen were cast cylinders bought a foot long that were tied directly to a rope. They helped with opening and closing the window.
  • Cvans said thank you
#5 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted August 10, 2015 - 09:20 PM
looks like a tape measure to me.
  • MH81, Cvans, Team_Green and 5 others have said thanks
#6 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Posted August 10, 2015 - 09:41 PM
Too small for a sash weight. I think it looks like some kind of fish, for fishing wires or such.
#7 HANKG OFFLINE
HANKG
  • 6,542 Thanks
  • 3,509 posts
Posted August 10, 2015 - 09:52 PM
Plumb bob ?
#8 Cvans ONLINE
  • 7,119 Thanks
  • 6,304 posts
Posted August 10, 2015 - 10:08 PM
Bunch of good suggestion.
I doesn't weight much, maybe an ounce and a half. Someone out there hopefully has seen something like this before.
#9 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted August 10, 2015 - 10:38 PM
That was not anywhere near an old chimney was it? When I was very young, dad had a gas furnace installed.
They did not run the stack up the chimney because it was soft brick and the mortar was rotten.
Dad took out the chimney.
I remember dad put a pulley on a board across the top ran a rope through that with a simular weight on the end.
He would fill a bucket with bricks and lower a guy on the bottom would lower it empty the bucket and then pull it back to the top.
A hook on the end would allow it to be secured so it could not fall. Now remember I was only about 5 yrs old so the details could be skewed?
The weight kept the rope from going through the pulley
Edited by JD DANNELS, August 10, 2015 - 10:40 PM.
  • Alc and Cvans have said thanks
#10 Cvans ONLINE
  • 7,119 Thanks
  • 6,304 posts
Posted August 10, 2015 - 10:43 PM
Interesting story and it makes sense to use this for something like that.
No old chimney at this residence. House was built in the 70's and had a stainless chimney.
#11 Bill 76 ONLINE
Bill 76
  • 2,001 Thanks
  • 1,204 posts
Posted August 11, 2015 - 12:17 AM
Maybe a headache ball for a toy crane  ?
#12 glgrumpy OFFLINE
  • 8,742 Thanks
  • 7,978 posts
Posted August 11, 2015 - 12:28 AM
I was gonna say window weight hook, to hang weight from. Or...hook from toy crane or truck, erector set? Got beat on those.
#13 Cvans ONLINE
  • 7,119 Thanks
  • 6,304 posts
Posted August 11, 2015 - 08:44 AM
This is something that is a real possibility. It would have been a larger than normal toy for sure.
#14 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,580 Thanks
  • 2,906 posts
Posted August 11, 2015 - 10:17 AM
It's used to hook onto the sash weight in a window. I have pulled a lot of those from windows when I was helping my dad tear down an old farm house back in the 60s. Top of the weight is elongated with the the same bevel as the hook. The rope ties to the hook. JM2CW !      Thanks for sharing.                                                            Roger
  • MH81, Alc, KennyP and 2 others have said thanks
#15 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 13,898 Thanks
  • 10,057 posts
Posted August 11, 2015 - 11:21 AM
Oh! So if you remove the weight, you don't loose the rope.
