520-HC added to collection
16 replies to this topic
#1 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,426 Thanks
  • 1,857 posts
Posted August 10, 2015 - 11:59 AM
Well this past Friday I traded my Allis B-212 for a Wheel Horse. I also have the 60" deck for it as well. Right now my problem is the engine surges but when i put choke on a little bit it smooths out. Carb is dirty right? Also I was wondering what year it might be as well.
  • Gtractor, Alc, boyscout862 and 3 others have said thanks
#2 EricFromPa ONLINE
EricFromPa
  • 4,015 Thanks
  • 3,270 posts
Posted August 10, 2015 - 12:38 PM
Could be old gas or dirty carb or partly clogged fuel filter or collapsed fuel line or Fuel pump needing rebuilt.Could be anything really but I'm leaning towards dirty carb or Fuel pump.
Surging is either a Lean condition or timing is slightly off.Either way I would not run it very long till it's fixed.Lean running engine runs very hot.It's really hard on the pistons,rings,connecting rods,head gaskets,heads an valves.
  • VintageIronCollector said thank you
#3 VintageIronCollector OFFLINE
  • 1,426 Thanks
  • 1,857 posts
Posted August 10, 2015 - 01:02 PM
I blew out carb a little and it fixed it but then the next morning was surging again. Probably sucked up a piece of dirt or something?
#4 Cat385B OFFLINE
    HAZMAT CAT
  • 14,289 Thanks
  • 10,116 posts
Posted August 10, 2015 - 02:44 PM
I would pull the tank and work towards the engine with new hose and a filter.
Does it have the forward swept front axle?
#5 VintageIronCollector OFFLINE
  • 1,426 Thanks
  • 1,857 posts
Posted August 10, 2015 - 03:47 PM
yup. I was told all the 520-HC had beefier steering
  • Cat385B said thank you
#6 case442 ONLINE
case442
  • 694 Thanks
  • 424 posts
Posted August 10, 2015 - 04:09 PM
I believe they were made in 1989 if I'm not mistaking. I believe they had a faster ground speed also. At least faster than the standard 520h.
HC standing for hydro commercial. I think you'll be very pleased with it. However the on and are very thirsty.
Mike
  • Alc and VintageIronCollector have said thanks
#7 KC9KAS OFFLINE
KC9KAS
  • 5,445 Thanks
  • 4,712 posts
Posted August 10, 2015 - 05:03 PM
If the model number is C1-20OE02, then it is a 1989 520-HC.
  • Cat385B and VintageIronCollector have said thanks
#8 VintageIronCollector OFFLINE
  • 1,426 Thanks
  • 1,857 posts
Posted August 10, 2015 - 06:09 PM
My sticker is ate up pretty good all I can read is E02     20530. So yea probably the 1989 then.
Anyone know where I could get another sticker made?
Edited by VintageIronCollector, August 10, 2015 - 06:09 PM.
#9 DH1 ONLINE
DH1
    Electric Tractors
  • 5,380 Thanks
  • 5,611 posts
Posted August 10, 2015 - 06:38 PM
I always wanted one like that with the big mower deck on it, maybe someday I find one.
Good Stuff
#10 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 13,931 Thanks
  • 10,067 posts
Posted August 11, 2015 - 11:29 AM
Your coming up in the world now. All the WH lovers will be making eyes at your tractor, and the girls at the drive-in will want a ride.
Another thing to check is if you have a leaking carb/engine gasket.
#11 VintageIronCollector OFFLINE
  • 1,426 Thanks
  • 1,857 posts
Posted August 11, 2015 - 11:42 AM
Yesterday when I was working on taking off the intake manifold I noticed two bolts on one side were loose so I tightened them and blew out the carb through the top 3 holes. Seems to run smooth now. Might still end up taking off carb to give it a good cleaning though.
#12 VintageIronCollector OFFLINE
  • 1,426 Thanks
  • 1,857 posts
Posted September 11, 2015 - 08:01 PM
right now fender deck is off getting painted. Got another seat for it, steering wheel cap, throttle knob, and gas cap off a parts 518 this past Monday.
#13 VintageIronCollector OFFLINE
  • 1,426 Thanks
  • 1,857 posts
Posted September 28, 2015 - 10:33 PM
Here's what she looks like now
  • KennyP and MolonLabe have said thanks
#14 KennyP OFFLINE
  • 40,240 Thanks
  • 46,811 posts
Posted September 29, 2015 - 04:11 AM
Nice looking Horse!
#15 VintageIronCollector OFFLINE
  • 1,426 Thanks
  • 1,857 posts
Posted October 24, 2015 - 03:18 PM
Got new tubes put in the front tires and got her out and ran her for a little while
  • Cvans and MolonLabe have said thanks
