What does this snow blade fit
18 replies to this topic
#16 Marlatt00 OFFLINE
Marlatt00
  • 6 posts
Posted August 10, 2015 - 07:37 PM
Okay any ideal on a price or what they go for atleast
#17 glgrumpy OFFLINE
  • 8,803 Thanks
  • 8,009 posts
Posted August 11, 2015 - 03:24 AM
$100 to $150 at most shows I go to. I've paid as little as $50 and Have seen asking $200, but bet they never got that much. As noted, they won't mount up to ANY tractor w/out the axle mount or similar home made item to hold up the back and give good push base. They can be expensive to find that mount when alone, but not real rare.  I see the hand lever for turning is on it and the wires, that is another item missing on many offers. This one DOES look real nice.
  • MolonLabe said thank you
#18 Tankman OFFLINE
Tankman
  • 299 Thanks
  • 299 posts
Posted September 01, 2015 - 07:37 PM
That blade will fit short or long frames including B, C, 300, 400 and 500 series. Nice score.
Fit a 500 series unless you have the swept forward front axle.
I added 4-1/2" to a frame, as shown, to clear the front tires if I angled the blade.
#19 Tankman OFFLINE
Tankman
  • 299 Thanks
  • 299 posts
Posted September 01, 2015 - 07:45 PM
What would it be work with out having parts for axle attachment?
You can find, or make mounting angles.
I once used 1/4" thick angle iron (3" x 3" x 4" long if I remember correctly). The angle iron I drilled a 3/4" clearance hole(s) in for the frame end rod(s). The side with the 3/4" dia holes I 45'd 3/4" x 3/4" to avoid the pointed ends.
Top flange of the angle iron, two 3/8" clearance holes for mounting boots. Two pieces of 2" flatbar, matching holes for the angle iron. Mounting holes spaced to bolts clear the axle.
When I mounted the frame, bolted the angle irons to the axle, there was no quick release for the plow frame.
Worked great.
Edited by Tankman, September 01, 2015 - 08:19 PM.
