What does this snow blade fit
18 replies to this topic
#1 Marlatt00 OFFLINE
Marlatt00
  • 6 posts
Posted August 08, 2015 - 08:05 PM
What model numbers does this blade fit an is it missing anything by chance got it cheap enough that I couldn't pass it up for the condition thanks
#2 NUTNDUN OFFLINE
  • 10,351 Thanks
Posted August 08, 2015 - 08:57 PM
Picture or description of it would be most helpful.
  • Gtractor, MH81, EricFromPa and 2 others have said thanks
#3 pharmer ONLINE
pharmer
  • 892 Thanks
  • 785 posts
Posted August 09, 2015 - 10:01 AM
That looks like it will fit anything you want it to.
#4 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted August 09, 2015 - 10:11 AM
I can't see anything....
#5 glgrumpy OFFLINE
  • 8,803 Thanks
  • 8,009 posts
Posted August 09, 2015 - 10:47 AM
Must be white one, or old picture of it in a snowstorm??   I'm betting it would fit between 2 and 8" of snow, maybe a little more if you get good run at it and traction. Better in fresh snow before it freezes into harder ice and won't clean well.
#6 Marlatt00 OFFLINE
Marlatt00
  • 6 posts
Posted August 09, 2015 - 05:02 PM
https://www.google.c...ONLd5aoqlCfaOM:
It's this style
#7 MolonLabe OFFLINE
MolonLabe
    Rust Wrangler
  • 558 Thanks
  • 321 posts
Posted August 09, 2015 - 05:37 PM
You need to include pics of the one you have, the google pics are a hodgepodge of blades, long and short frame and home made. Also tell us what model Wheel Horse you intend to mount this on and whether or not you have the rear axle attachment for it like the one below.
#8 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,101 Thanks
  • 10,172 posts
Posted August 09, 2015 - 07:07 PM
Mainly, I believe there are three different plows. The difference is the length of the undercarriage. There is a so called "long frame", a "short frame" and some models of the B series are in between. If your not really familiar with Wheel Horse, you need to have the correct model numbers of tractor and plow. Does your plow still have the model numbers on it?
#9 Marlatt00 OFFLINE
Marlatt00
  • 6 posts
Posted August 09, 2015 - 10:20 PM
#10 Marlatt00 OFFLINE
Marlatt00
  • 6 posts
Posted August 09, 2015 - 10:24 PM
It has the I'd tag lily!!
06-42bc01-3080
The I'd tag number
#11 MolonLabe OFFLINE
MolonLabe
    Rust Wrangler
  • 558 Thanks
  • 321 posts
Posted August 10, 2015 - 06:11 AM
That blade will fit short or long frames including B, C, 300, 400 and 500 series. Nice score.
#12 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,101 Thanks
  • 10,172 posts
Posted August 10, 2015 - 01:01 PM
That looks to be in pretty nice shape. Is the blade good? You probably know this, but just in case; you want to be sure and not let the blade wear down to where you are grinding into the mold board behind it. When it does wear down, you can take it off and turn it up side down.
#13 KC9KAS OFFLINE
KC9KAS
  • 5,460 Thanks
  • 4,719 posts
Posted August 10, 2015 - 05:11 PM
Marlatt00, :welcometogttalk: ...Nice find!
#14 Marlatt00 OFFLINE
Marlatt00
  • 6 posts
Posted August 10, 2015 - 06:05 PM
What would it be work with out having parts for axle attachment?
#15 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,101 Thanks
  • 10,172 posts
Posted August 10, 2015 - 06:16 PM
That blade looks to be about new. I don't think you necessarily have to include a mount with it. Those mounts are used for other accessories besides the plow.
