'59 suburban....
4 replies to this topic
#1 WHdbJD ONLINE
WHdbJD
  • 649 Thanks
  • 488 posts
Posted August 07, 2015 - 06:10 PM
Not getting the "snap" when the clutch is engaged on my 1959 db suburban.
Took the wheel/tire and the belt guard off to adjust the clutch and......
OH , NO!  the po had tightened the set bolt down on the threads, instead of
the flat spot!!!  And of course damaged the threads
Now what???  With the rust and the damaged threads, how the heck can I fix this?
( tried to put a picture, but kept getting error message)
#2 IWLBCNU OFFLINE
IWLBCNU
  • 120 Thanks
  • 158 posts
Posted August 10, 2015 - 09:20 AM
You just have to oil it and work the hub back and forth a little at a time and it will finally chase the threads.
  • WHdbJD said thank you
#3 WHdbJD ONLINE
WHdbJD
  • 649 Thanks
  • 488 posts
Posted August 10, 2015 - 06:11 PM
thanks for the reply!  sounds like a project for this winter with a good supply of PB Blaster,
a fire wrench, and a large pipe wrench!
#4 jabelman OFFLINE
jabelman
  • 1,876 Thanks
  • 1,353 posts
Posted August 10, 2015 - 08:04 PM
I bought mine last fall and soaked all winter. Everything freed up by spring when I rebuilt mine. I didn't heat mine I wouldn't recommend it. Just patience and working it freed it up. I don't think it's to easy to find clutch parts
Edited by jabelman, August 10, 2015 - 08:07 PM.
#5 WHdbJD ONLINE
WHdbJD
  • 649 Thanks
  • 488 posts
Posted August 11, 2015 - 03:29 PM
You're correct Jabelman.  I think I best leave the torch out of this fight!
