Ford T1000/Jacobsen trans belt shield
20 replies to this topic
#16 acwd45 OFFLINE
acwd45
  • 18 Thanks
  • 22 posts
Posted August 12, 2015 - 01:19 PM
Mine is starting to look like something again
  • VintageIronCollector said thank you
#17 Ford Chet OFFLINE
Ford Chet
  • 48 Thanks
  • 38 posts
Posted September 28, 2015 - 07:31 AM
Attached File  Before Ford120 picture.htm   123.24KB   33 downloadsAttached File  Before Ford120 picture.htm   123.24KB   33 downloadsFord 120 Hydro Pump.jpg Attached File  Before Ford120 picture.htm   123.24KB   33 downloadsFord 120 Hydro Pump.jpg Frame-complete transaxle with all controls installed drive no drive fixed. 9-27-15.jpg Frame-rear 10-22-15.jpg Frame-Rear-Transmission 09-23-15.jpg Front Axle and Dash board..jpg Rear End.jpg Rolling Frame.jpg Transaxle with controls installed 9-28-15.jpg
Mine is completely blown up. I am working on getting the frame and front axle painted so I can start reassemble. Nut and bolt restorations are time consuming. If it's not right you gotta fix it lol.
I have a 1970 Ford 120 I tore it down to the frame and started restoring every thing back up.  Every part was stripped of the paint then primer (3 coats) then top coat (3 coats) then clear coat (3 coats).  I included a couple of pics.  You are right...it is very time consuming and very satisfying  ! :wave:
#18 Dayton_King ONLINE
Dayton_King
  • 1,263 Thanks
  • 1,056 posts
Posted September 29, 2015 - 07:56 AM
That belt guard for the T, the one I have in the pic is for sale. I bought a other tractor with a high-low and I am using the guard because it's special
#19 acwd45 OFFLINE
acwd45
  • 18 Thanks
  • 22 posts
Posted September 29, 2015 - 09:28 PM
How much do you want for it? I havent got anything made for mine yet.
#20 Dayton_King ONLINE
Dayton_King
  • 1,263 Thanks
  • 1,056 posts
Posted September 30, 2015 - 08:51 PM
P.m. me an offer. I can't use it because the hi-low uses a different shield. I had it welded, so it will only needs minimal work.
#21 Dayton_King ONLINE
Dayton_King
  • 1,263 Thanks
  • 1,056 posts
Posted October 15, 2015 - 07:51 PM
The belt guard was picked up today, ups is slow. So it's on its way
