Picked up an Economy tractor
kohler economy rebuild
5 replies to this topic
#1 CRE1992 OFFLINE
CRE1992
  • 28 Thanks
  • 49 posts
Posted August 06, 2015 - 09:45 PM
Hey fellas haven't really been on in awhile. I moved from NJ to NC earlier in the year and I was really busy and hadn't planned on getting back into garden tractors for a little while until a really nice economy 2414 tractor popped up on craigslist with a blown engine. So it needs a rebuild, definitely has a broken rod. Its in really great shape and came with front wheel weights, front dozer/snow plow, and a rear moldboard draw bar mount plow. Best part is, it has hydraulic lift! Anyone know of a K series engine rebuilder in South Eastern NC? I want to have it rebuilt. Also does anyone know the gpm and psi output of the hydraulic pump, and also what size ports are on it.
Thanks,
Charles
55b4e3032a455_20150725_1256491.jpg.27ae455b4e322b8b12_20150726_0817211.jpg.ad5dc
Edited by CRE1992, August 06, 2015 - 09:49 PM.
  • Gtractor, MH81, Alc and 3 others have said thanks
#2 MNGB OFFLINE
MNGB
  • 2,625 Thanks
  • 1,569 posts
Posted August 06, 2015 - 10:07 PM
Nice looking tractor, and some nice attachments you'll have a good tractor when you get the engine overhauled.
Edited by MNGB, August 06, 2015 - 10:07 PM.
#3 glgrumpy OFFLINE
  • 8,816 Thanks
  • 8,014 posts
Posted August 06, 2015 - 11:07 PM
Really nice tin on that one. Why can't you do your own rebuild? What you need to look for is how much damage to other parts when rod broke. Kits on epay all the time for good prices. Manuals to download from Kohler or here with procedures. Pumps are rated 1000psi I believe, and real low on gpm, like 2, but not certain. IF you were thinking of a loader, they DID have bigger volumn pump for those, seems pressure was 2000 and gpm in 7 range, but would have to look for sure. Otherwise that pump is plenty for any other attachment you may need to lift. The blade is pretty heavy and it does those easy. Front weights are rarity, and rears cab just be off a IH Cub or A size tractor, same wheels.
  • MH81 and TomLGT195 have said thanks
#4 MH81 OFFLINE
  • 29,979 Thanks
Posted August 07, 2015 - 06:28 AM
Nice Economy!
Hope the nine doesn't need much.
#5 CRE1992 OFFLINE
CRE1992
  • 28 Thanks
  • 49 posts
Posted August 07, 2015 - 07:51 AM
Thanks that is why I saved it! I don't really have the time to rebuild it, and I was asking about the hydraulics because I am thinking of adding different attachments for it. Hydraulic dump trailer, 4 way loader valve for hydraulics on the blade. Eventually find a 3pt off of a newer one. Obviously all to come in the future. I work at a shop where I am fully capable of tearing it down if I wanted to, but the tractor is over and hour away from me because I live near the beach and I don't have much room to play with anything so I keep it elsewhere. There's a really good well known and reasonable machine shop nearby that will bore and hone the engine if I get a piston and make sure the block is to spec, lap the valve seats and match the valves for $75.
Edited by CRE1992, August 07, 2015 - 07:58 AM.
#6 Austen ONLINE
Austen
  • 1,780 Thanks
  • 947 posts
Posted August 13, 2015 - 11:34 AM
Nice tractor!
Also tagged with one or more of these keywords: kohler, economy, rebuild
