1250 mower lift mechanism
5 replies to this topic
#1 buicfrank OFFLINE
buicfrank
  • 4 Thanks
  • 11 posts
Posted August 06, 2015 - 09:42 PM
On my 1250 when I use the hydraulic lift for the mower deck, it picks up only on the right side. I have replaced the small levers on the attachment frame.  Got it to cut level now, but it won't lift equally. HELP NEEDED.  Thanks Frank
#2 KennyP ONLINE
  • 40,874 Thanks
  • 47,091 posts
Posted August 07, 2015 - 06:06 AM
That sounds like a broken roll pin on one lift arm.
#3 Jlaws OFFLINE
Jlaws
  • 556 Thanks
  • 368 posts
Posted August 07, 2015 - 10:50 AM
I agree with Kenny on the broken roll pin as the most likely cause . I'd get someone to raise and lower it while you observe the rockshaft lift arms  to confirm that both arms are moving the same . Just be careful when observing it .
Edited by Jlaws, August 07, 2015 - 10:52 AM.
#4 buicfrank OFFLINE
buicfrank
  • 4 Thanks
  • 11 posts
Posted August 08, 2015 - 08:12 PM
The roll pin is what is broken. Thank you for the replies.  Frank
#5 KennyP ONLINE
  • 40,874 Thanks
  • 47,091 posts
Posted August 09, 2015 - 04:55 AM
Glad you found the issue!
  • buicfrank said thank you
#6 buicfrank OFFLINE
buicfrank
  • 4 Thanks
  • 11 posts
Posted August 12, 2015 - 09:53 PM
Kind of a bear to replace without tearing everything apart. But I figured it out. Hardest part was grinding the frame to let the pin go in strainght.  Thank you for the replies.  Frank
