Stihl 044
stihl 044 pull start chainsaw
28 replies to this topic
#16 Lumberlady OFFLINE
Lumberlady
  • 11 Thanks
  • 15 posts
Posted August 07, 2015 - 05:59 PM
Sounds like you will get it going soon. Will like to know what you find. Noel
Will do. Still plugging away.
  • propane1 said thank you
#17 Jazz ONLINE
Jazz
  • 2,394 Thanks
  • 1,443 posts
Posted August 07, 2015 - 07:21 PM
I should be able to hear your saw when you rev it up..I be just upwind at camp for a couple weeks on the Montreal River.. I launch at Mowats Landing. I have a smaller Stihl and never had a issue in the 20 years I've owned it,,,
  • Lumberlady said thank you
#18 propane1 OFFLINE
propane1
  • 8,725 Thanks
  • 4,131 posts
Posted August 08, 2015 - 08:32 AM
Found out some information. That saw is normally harder to pull over compared to smaller saws , but it has a decompression valve that has to be manually pushed in before starting. If it's not pushed in it will be very hard to pull over. So this button is on the top of the saw some where. I has to be push in for each try of starting. Hope this helps. Noel
Edited by propane1, August 08, 2015 - 08:36 AM.
#19 Lumberlady OFFLINE
Lumberlady
  • 11 Thanks
  • 15 posts
Posted August 08, 2015 - 09:33 AM
Unfortunately I bought this saw second hand and do not know the history of it. I see the flywheel has a fin missing now. Montreal river is not far from here.
Edited by Lumberlady, August 08, 2015 - 09:57 AM.
#20 Lumberlady OFFLINE
Lumberlady
  • 11 Thanks
  • 15 posts
Posted August 08, 2015 - 09:37 AM
This particular model does not have a decompression valve and was not as difficult to pull start before the problem occurred.
#21 Lumberlady OFFLINE
Lumberlady
  • 11 Thanks
  • 15 posts
Posted August 08, 2015 - 09:56 AM
If the ignition is not functioning correct can it be lead to a hard pulling over of the engine?
#22 propane1 OFFLINE
propane1
  • 8,725 Thanks
  • 4,131 posts
Posted August 08, 2015 - 10:58 AM
Timing problem, not firing at the right point ? Having a fin broke may put it out of balance. Noel
Edited by propane1, August 08, 2015 - 11:04 AM.
#23 propane1 OFFLINE
propane1
  • 8,725 Thanks
  • 4,131 posts
Posted August 12, 2015 - 05:33 PM
Did you get it going ? Just wondering what was wrong. Noel
#24 Lumberlady OFFLINE
Lumberlady
  • 11 Thanks
  • 15 posts
Posted August 13, 2015 - 12:22 PM
Cc Bought a junk 038 Stihl and used the ignition coil and she runs marvelous. Still a little bit difficult to pull, but not like it was.  Cuts like a hot knife through butter now. May still need a new carb kit. Will keep you posted.  Thanks for the help. Will keep you posted. (my main profession is author, after all! LOL)
  • WNYTractorTinkerer and propane1 have said thanks
#25 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 10,470 Thanks
  • 5,770 posts
Posted August 13, 2015 - 12:32 PM
Looks like we will be hearing alot out of you then LL!
Glad you got it going and hope the 38 was cheap..  The coils really aren't that expensive..  Here's a total tuneup KIT
#26 propane1 OFFLINE
propane1
  • 8,725 Thanks
  • 4,131 posts
Posted August 13, 2015 - 01:08 PM
Thats great. Glad you got it going. you should open a small engine repair shop on the side too.   Noel
#27 Lumberlady OFFLINE
Lumberlady
  • 11 Thanks
  • 15 posts
Posted August 13, 2015 - 01:12 PM
Everything in Canada is more expensive than the US! Paid only $20 for our 038. Got a new coil and a spare pulley. I am pleased with the purchase because of the benefits. Just wondering if the carb is the same size.
#28 Lumberlady OFFLINE
Lumberlady
  • 11 Thanks
  • 15 posts
Posted August 13, 2015 - 01:16 PM
Don't believe so, but you never know!
#29 Lumberlady OFFLINE
Lumberlady
  • 11 Thanks
  • 15 posts
Posted August 13, 2015 - 01:26 PM
Thank you for the encouragement but I only cut out of necessity. Am off grid most of the year. Have to keep watching through the winter months!
Also tagged with one or more of these keywords: stihl 044, pull start, chainsaw
