Ariens GT 17 doesn't crank
16 replies to this topic
#16 artbuc OFFLINE
artbuc
  • 72 Thanks
  • 158 posts
Posted August 11, 2015 - 05:50 PM
Well, if you have voltage to switch and a new switch, I assume you have voltage leaving the switch when you crank. But you say you have no voltage from your ignition switch at the solenoid. That means the wire from your switch to your solenoid must be broken. Did you check for continuity betwen switch and solenoid? Did you check your new switch? Is it wired properly?
Edited by artbuc, August 11, 2015 - 05:51 PM.
#17 artbuc OFFLINE
artbuc
  • 72 Thanks
  • 158 posts
Posted August 25, 2015 - 02:28 AM
What happened Spencer? Did you find the problem?
