told em not to use ethanol !
5 replies to this topic
#1 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted August 05, 2015 - 04:54 PM
WTF IS THIS ??? its like concrete .  It must be global warming
  • Gtractor and Jazz have said thanks
#2 JD DANNELS OFFLINE
JD DANNELS
  • 3,786 Thanks
  • 3,907 posts
Posted August 05, 2015 - 06:41 PM
Lime deposits. Alcohol will absorb water. Look at the contents of Heet, a fuel additive used to absorb water in your fuel tank and prevent gas line freeze. Rarely will you see it that bad. But I have seen the lime deposits from fuel absorbed water I might add that I have never had to use Heet since I started using ethanol.
Now having ran ethanol since the gas shortage in the 70s, I am not the one to get into a discussion about ethanol.
Edited by JD DANNELS, August 05, 2015 - 07:19 PM.
  • sodisr, propane1 and alec have said thanks
#3 sodisr OFFLINE
sodisr
  • 661 Thanks
  • 771 posts
Posted August 06, 2015 - 08:49 AM
Alec,,,   Had a similar situation on my Holly 4 bbl.  It was more like a large snow-flake of white crap.  When I accelerated it would get sucked up to the needle and cause it to bog.. It was a tough one to figure out.  Took the bowls off and there it was..It also started to eat at the aluminum  bowls.. I could pinch the flake and it would turn to powder.. Was told it was the ethenal blend in our gas...
  • alec said thank you
#4 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,170 Thanks
  • 5,768 posts
Posted August 06, 2015 - 09:33 AM
Ethanol is nasty!
#5 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted August 06, 2015 - 09:52 AM
when I took the hs needle out the hole was full of it , when I tried to blow it out bubbles came out the side of the casing .had to drill out the needle . hoping I can use the top half to replace one with stripped mounting holes . the float still floats . but it munched on the casing pretty good
#6 tater195 ONLINE
tater195
  • 1,585 Thanks
  • 1,070 posts
Posted August 06, 2015 - 11:07 AM
My ford 3000 carb was like that when I got it. Fuel bowl on the carb was full of the flakey stuff. The sediment bowl was full of yogurt and the fuel tank turned to goo and flash rusted. I had to replace the carb because it corroded so bad the bowl had pin holes in it
