Got a Farmall A + LOTS MORE!
24 replies to this topic
#1 BTS ONLINE
BTS
    Make Stuff Up
  • 4,743 Thanks
  • 2,667 posts
Posted August 03, 2015 - 10:19 PM
I just picked this up today, I bought it all in a "package deal" from a guy 4 miles away. It's a 1944 Farmall A, with a home built 3-pt, the 3-pt is really stout and well made. The tractor came with a old stationary engine (basically a farmall A engine), it is stuck, manifold is rusted off and gone!. But it's on a very well made heavy skid that I will probably cut up and use the metal on another project. The tractor came with the hood, grill, fenders (fenders don't fit with the 3-pt), original seat assembly, angle gear box for the PTO to run a belly mower (no mower included), original draw bar and some other mics pieces.
The attachments that came with it are a home built boom pole, home build single bottom plow (14" made out of a old draw bar 2 bottom plow), draw bar for 3-pt (been wanting one since I got a tractor with a 3-pt), old time 3-pt dirt slip and a John Deere 4 section disk that's probably 10' wide.
I haven't gotten the disk, dirt slip and plow yet. I'm going back with my little Kubota with loader to try and get them all loaded.
First thingI'm doing with the old A is buy a new set of rings for it, Wile it's pulled apart I will give it a coat of paint and then reassembly the old thing. It's then going up for sale, I guess I will see if it's worth anything? I paid $750 for the whole lot so I have a little room to work with.
  • Alc, wvbuzzmaster, IHCubGuy and 6 others have said thanks
#2 IHCubGuy OFFLINE
IHCubGuy
  • 1,616 Thanks
  • 1,639 posts
Posted August 03, 2015 - 10:59 PM
Nice score.  That engine looks like it might be a U-2 power unit as opposed to a combine engine.  What is on the tag on the bell housing if I might ask?
  • BTS said thank you
#3 BTS ONLINE
BTS
    Make Stuff Up
  • 4,743 Thanks
  • 2,667 posts
Posted August 03, 2015 - 11:02 PM
I'll take a look tomorrow
  • IHCubGuy said thank you
#4 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted August 03, 2015 - 11:17 PM
Great haul.
I have a U-4 power unit that might need a gas tank if you can't save that power unit.
  • superaben and BTS have said thanks
#5 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted August 04, 2015 - 04:34 AM
Nice A. I saw one on the weekend that looked a lot like yours. No hood, fenders etc. It wasn't for sale though.
#6 Alc ONLINE
  • 7,348 Thanks
  • 7,633 posts
Posted August 04, 2015 - 05:20 AM
Not a bad deal , if those tires are as good as they look you sell all of them for almost what you paid for the package
#7 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted August 04, 2015 - 06:48 AM
NICE!
#8 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted August 04, 2015 - 12:22 PM
They must irrigate a. Lot in ypur part of Kansas? That is a pump on that statuary right??
Nice score on all
Edited by JD DANNELS, August 04, 2015 - 12:24 PM.
#9 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted August 04, 2015 - 09:57 PM
Never leave a Farmall A to rot!  I've owned a couple, and I own a standard A with the exhaust lift now, as well as a Super A.  Tough little rascals.
The U4 unit is not something to be despised, either.  I know a couple guys who are starting to collect the older stationary power units like that.  I foresee those things become more valuable as they get older, just like the old hit and miss engines did.
If you want parts for that A, let me know.  I have quite a bit of Farmall rebuild parts in stock and I sell Hastings rings as well.
Ben W.
#10 BTS ONLINE
BTS
    Make Stuff Up
  • 4,743 Thanks
  • 2,667 posts
Posted August 04, 2015 - 10:22 PM
Here is the tag on the bell housing, the ser. # is UAA - 21510 Model U-2 A
#11 BTS ONLINE
BTS
    Make Stuff Up
  • 4,743 Thanks
  • 2,667 posts
Posted August 04, 2015 - 10:26 PM
Great haul.
Is the tank the same on a U-4 as a U-2 ? I don't know my stationary engines. The inside of the tank looks rusty and there is something in the tank and I'm not sure what it is???
#12 BTS ONLINE
BTS
    Make Stuff Up
  • 4,743 Thanks
  • 2,667 posts
Posted August 04, 2015 - 10:30 PM
The tires are pretty good, they have light weather cracks but nothing bad at all.
  • Alc and superaben have said thanks
#13 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted August 04, 2015 - 10:38 PM
There's your value right on those rims.  I've turned down decent tractors because of bad tires before, but I always buy junk tractors on good tires.  :rolling: :rolling:
Ben W.
  • Alc and BTS have said thanks
#14 BTS ONLINE
BTS
    Make Stuff Up
  • 4,743 Thanks
  • 2,667 posts
Posted August 04, 2015 - 11:18 PM
Ben W.
Thanks, I do need to look in to the right wheel, it has a wobble from side to side? the wheel is tight, it looks like the axle is loose in the housing? Any idea on what this could be? and is a big deal to fix it?.   I'm guessing a bearing is out?, but I don't know for sure.
Thanks for any info
#15 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted August 05, 2015 - 09:43 PM
The axle wobble sounds like either a loose wheel clamp (the four around the perimeter) or a bad bearing.  You'll want to get that fixed since a bad bearing will misalign the bull gear in that housing and (eventually) cause the bull and pinion to destroy themselves and chew the whole final drive up on that side.  You don't want that to happen.
Bearings are all universal on it, there is nothing odd or special that you cannot get matched up.
Make sure you add oil in that final drive.  They usually have been neglected through the years.
Ben W.
