Where can I find the clutch electrical connector for a JD 130 ?
6 replies to this topic
#1 gramparich OFFLINE
gramparich
  • 1 posts
Posted August 03, 2015 - 07:30 PM
I put the engine from my JD L130 into an older Scotts 2554 to eliminate the crappy transmission problem,
and sold the thing on craigslist.  Unfortunately,  the clutch harness stayed with the L130, and I can't find a
@#$%^  connector anywhere. I'm hoping one of you guys might know where I could find a used or new one........
Thanx,
Grampa Rich  (not rich grampa as the grand, and great grandkids think)
(Tin Can Sailor)
Edited by gramparich, August 03, 2015 - 08:02 PM.
#2 HDWildBill OFFLINE
  • 8,984 Thanks
Posted August 03, 2015 - 07:33 PM
Welcome aboard.  If you could provide a picture of the connector and or part number of the connector you are looking for that may help.  Another tractor could use the same clutch and connector harness.
  • gramparich said thank you
#3 Alc ONLINE
  • 7,259 Thanks
  • 7,597 posts
Posted August 03, 2015 - 08:31 PM
Welcome to GTTalk !
#4 KC9KAS OFFLINE
KC9KAS
  • 5,469 Thanks
  • 4,725 posts
Posted August 04, 2015 - 04:06 AM
:welcometogttalk:
I bought a bunch of connectors a couple of years ago to remake a wiring harness on a Wheel Horse.
I don't remember the company right now, but I will check this evening and respond.
They had everything imaginable.
#5 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted August 04, 2015 - 04:44 AM
If you can't find the connector you could hard wire it!  It would get you going. Another option is to find a lawn tractor recycler and get used parts through them. You could also check jdparts.com to see if a new part is available.
#6 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted August 04, 2015 - 06:55 AM
:welcometogttalk:
#7 KC9KAS OFFLINE
KC9KAS
  • 5,469 Thanks
  • 4,725 posts
Posted August 04, 2015 - 04:01 PM
Here is the place..........https://www.theelectricaldepot.com/
