need some help from fellow custom owners
6 replies to this topic
#1 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 288 Thanks
  • 232 posts
Posted August 03, 2015 - 07:04 PM
my dads 36 inch mower deck stripped splines  on the shaft well meantime we are going to weld the shaft to the gear box shaft like done to other side. but heres what i need we got a parts deck but need seals for bottom of gearboxs. so anyone know the numbner of the seal for replacement manuals dont show seal i looked in 2 of them
#2 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 288 Thanks
  • 232 posts
Posted August 03, 2015 - 07:19 PM
here is what i am talking about one showing bearings is parts deck other one is off the deck he has been using
  • Bolens 1000 said thank you
#3 Bolens 1000 OFFLINE
  • 14,987 Thanks
  • 18,140 posts
Posted August 04, 2015 - 06:52 AM
What is the bearings part number? Looks like the seal rides in the same OD and ID of the bearing, I should be able to cross the seal and may have it instock as well as the bearings if we can get a number or two.....
#4 Bolens 1000 OFFLINE
  • 14,987 Thanks
  • 18,140 posts
Posted August 04, 2015 - 07:14 AM
Now that I think of it, I believe these are Peerless made correct? , Is there any numbers on the gear case itself?
#5 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 288 Thanks
  • 232 posts
Posted August 04, 2015 - 08:43 AM
i will check when i go outside
#6 Buck Tales OFFLINE
Buck Tales
  • 187 Thanks
  • 122 posts
Posted August 10, 2015 - 09:18 PM
If you can't find any numbers then mic the shaft size and the opening plus the thickness of the seal. Look in a Chicago Rawhide cross referance manual for seals and should be able to get one to match perfectly. I do it in work alot for stuff with no numbers. be blessed :)
  • craftsmanmowerfreak said thank you
#7 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 288 Thanks
  • 232 posts
Posted August 10, 2015 - 11:38 PM
i just been busy with things and havent pulled it back apart to check lol
