MF7 Big problem need help!!!
36 replies to this topic
#31 KennyP OFFLINE
  • 53206 Thanks
  • 53318 posts
Posted April 08, 2011 - 06:22 AM
Is it a bolt or a set screw with the 5/16" X 24 thread? That is real close to a metric M8 X 1.25.
I am old school, as far as inches/metrics go. Which is bigger, cm or mm?
#32 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted April 08, 2011 - 06:36 AM
10mm in 1cm. 100cm in a meter.
One meter = (rounded) 3 ft 4 inches
That's all I remember :D
#33 KennyP OFFLINE
  • 53206 Thanks
  • 53318 posts
Posted April 08, 2011 - 06:56 AM
We didn't have all that when I was in school. Never have got a handle on it.
#34 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1082 posts
Posted April 08, 2011 - 09:56 AM
Kenny-> Bolt...I think. The type that you actually screw into the crank with a big washer to hold pulleys on.
#35 DMF OFFLINE
DMF
  • 16 Thanks
  • 285 posts
Posted April 08, 2011 - 11:31 AM
The new shaft is a touch shorter and I am pretty sure the set screw is gonna be right on the edge of that keyway.
Is that an inch or metric "touch"? :confuse:
Sorry, I just couldn't help myself! :smilewink:
Seriously, could you drill and re-tap the pulley further in where it sits on the shaft?
#36 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1082 posts
Posted April 08, 2011 - 11:58 AM
HAHAHA!! I don't think so, the belts would be off and it would rub on the engine. It is all pretty tight(metrically and stardardly speaking)...Besides, if I get the right bolt it should be fine...right?
#37 TUDOR OFFLINE
TUDOR
  • 573 Thanks
  • 507 posts
Posted April 08, 2011 - 05:54 PM
If you don't have an industrial supply house or a Fastenall handy, try a machine shop. A 5/16 x 24 NF thread is a standard size available in grade 2, 5 and 8 hex head as well as holochrome (socket head). DON"T use grade 2.
It's a common fastener, but there isn't much call for them.
