Sold
Simplicity Wonder Boys 3 of them
5 replies to this topic
#1 1oldbuzz OFFLINE
1oldbuzz
  • 564 Thanks
  • 448 posts
Posted August 02, 2015 - 02:44 AM
3 wonder boys
404
575
606
All run and drive.all will need various TLC
been in storage for 20 years
404-$250
575-$250
606-$300
or all 3 for $650
going to stay firm on prices
There is a Fastenal close to me
Manitowoc WI 54220
will drop off
Buyer to set it up and make all arangements
will post all numbers I can find later today
I can get more pics to serious buyers
404 seems to be burning a little oil or may be the sea foam treatment
runs good cuts nice solid deck
points and flywheel have been cleaned
not sure if engine is original
I don't think the seat is original
grounding wire for kill is not working
Fresh oil
will need front wheel bushings replaced and should have new belts
575 joy stick has new points fresh oil I do not believe it is the original engine has a 7 horse briggs
should have carb rebuilt and  will need belts also smokes a little but again may be the sea foam treatment kill wire not working
also should have front wheel bushings replaced
rear of engine cover looks to have been modified/cut
I have the deck for this one just not on the machine
nice solid deck
606 this one is the nicest of the 3
 cleaned points,tank new fuel line fresh oil may need a carb rebuild also belts
has ring gear on flywheel for electric start also has sea foam treatment smokes a little
should have valves adjusted as you can hear a lifter ticking
kill wire will need to be looked at works when it wants to
I have 2 spare engine covers/hoods for this one
Does a fantastic job cutting and I didn't even sharpen the blades solid deck
 better than my $350 walk behind
  • Texas Deere and Horse, karel and oldiron1 have said thanks
#2 1oldbuzz OFFLINE
1oldbuzz
  • 564 Thanks
  • 448 posts
Posted August 15, 2015 - 01:43 PM
Update
Going to offer a second 575
PO started to restore and gave up
has original 5.75 briggs  has a new rebuilt carb
will run it is missing the control rod to the governor
engine cover has a few dents and dings
deck needs 1 bracket welded and needs a cleaning
Looking for $425 on the pair
#3 1oldbuzz OFFLINE
1oldbuzz
  • 564 Thanks
  • 448 posts
Posted August 24, 2015 - 05:08 AM
Any takers at $350 on the pair of 575's
need to make room
#4 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted August 24, 2015 - 03:07 PM
Shipping would EAT me up.
#5 IH nut OFFLINE
IH nut
  • 19 Thanks
  • 20 posts
Posted December 04, 2015 - 03:12 AM
I'm gonna see if I have any friends heading my way for the pair of 575s
#6 1oldbuzz OFFLINE
1oldbuzz
  • 564 Thanks
  • 448 posts
Posted December 09, 2015 - 05:22 AM
Sold
Also tagged with one or more of these keywords: Sold
