Wanted
Cub Cadet super steer front axle
4 replies to this topic
#1 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted August 01, 2015 - 09:43 PM
Any chance anyone have a Cub Cadet "super steer" front axle. Should have 1" spindles and fit all the early Cub Cadets as well. Looking to replace the worn out front axle on my Cub Cadet 102 that I am planning to build a small loader for.
Edited by wvbuzzmaster, August 01, 2015 - 09:44 PM.
#2 classic ONLINE
classic
  • 5,203 Thanks
  • 2,247 posts
Posted August 01, 2015 - 11:08 PM
There are a couple of versions of the super steer front axle. One has taller spindles and will make the front end sit too high. Some of the cast iron axles were swept back, too. You will want the straight axle with the short spindles for your 102. Try to get the tie rod, drag link, and splined Pittman arm, also.
  • MH81, Alc and wvbuzzmaster have said thanks
#3 case442 ONLINE
case442
  • 693 Thanks
  • 423 posts
Posted August 02, 2015 - 06:59 AM
Hi Casy
I have one if your interested.
Mike
  • MH81 and wvbuzzmaster have said thanks
#4 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted August 02, 2015 - 10:46 AM
Hi Casy
Mike
I asked you what else you were hiding back in May lol. I should definitely stop by and see you sometime.
#5 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted January 31, 2016 - 08:18 PM
Going to bump this back to the top. I am now looking for the other version of the super steer axle for my 108. I do not want the forward swept axle with tall spindles like I put on the 102, but now the straight axle with short spindles. Could also want just the short 1" spindles for the 102 to run a taller front tire (already have 26" tall rears).
