Bevel gear box rebuild help
16 replies to this topic
#1 Dayton_King ONLINE
Dayton_King
  • 1,256 Thanks
  • 1,052 posts
Posted August 01, 2015 - 06:07 PM
I have this bvg on a B10 Frame that is destined for the junk pile. I have never rebuilt a bvg. The one on my junker b10 started making noise and i checked and I have a lot of play.
So this bvg is nice and tight but has some play not bad but if I am going to replace it might as well make it right. My 2 problems at the moment are, set screw is siezed still after 3 days of pb blaster and acetone/atf. My second problem is what size nut on transmission side? I don't have my tools at home. I want to make it right.
Edited by Dayton_King, August 01, 2015 - 06:08 PM.
#2 Marty'70 ONLINE
Marty'70
    I didn't do it! Unless you have paperwork to back it up
  • 862 Thanks
  • 719 posts
Posted August 01, 2015 - 07:03 PM
If its not too close to the seal, I would try some heat on the set screw.
#3 MH81 OFFLINE
Posted August 01, 2015 - 07:15 PM
I agree, make a tin shield and protect it s much as you can, then heat
If you turn that side up, is there a place you could pour in water as a protector for the seal, etc? You're just trying to heat the metal around the setscrew, not the shaft or the screw, so water might help
#4 Dayton_King ONLINE
Dayton_King
  • 1,256 Thanks
  • 1,052 posts
Posted August 01, 2015 - 07:24 PM
I am planning on seals, I will try heat tomorrow. My little propane torch did not want to corporate tonight so I will go buy a new one.
#5 classic ONLINE
classic
  • 5,209 Thanks
  • 2,248 posts
Posted August 01, 2015 - 09:32 PM
Get yourself a good punch that will bottom out in the set screw. Give it a few shots with a hammer and it will help loosen it up. I was able to remove many this way. This also works well on oil drain plugs.
  • KennyP, VintageIronCollector and propane1 have said thanks
#6 MH81 OFFLINE
Posted August 02, 2015 - 06:41 AM
Propane torch may not get it. The heat is lower and slower.
Do you have a neighbor with oxy-acet torches?
#7 Dayton_King ONLINE
Dayton_King
  • 1,256 Thanks
  • 1,052 posts
Posted August 09, 2015 - 12:22 PM
Still no luck, if I can't get it out by tomorrow night I will drill it ouy
#8 Dayton_King ONLINE
Dayton_King
  • 1,256 Thanks
  • 1,052 posts
Posted August 09, 2015 - 04:26 PM
Partial victory. Got the drive shaft coupler off. Now the question is how do I get the nut off. Is it reverse thread?
#9 KennyP ONLINE
  • 38,385 Thanks
  • 45,933 posts
Posted August 09, 2015 - 04:41 PM
I just went out and looked at the 716 BGB and it is RH thread. Not sure if it's the same as yours!
#10 Dayton_King ONLINE
Dayton_King
  • 1,256 Thanks
  • 1,052 posts
Posted August 09, 2015 - 04:52 PM
I must be weak. I will get a socket from work, none that I have will fit it.
#11 Dayton_King ONLINE
Dayton_King
  • 1,256 Thanks
  • 1,052 posts
Posted August 09, 2015 - 06:21 PM
I pulled the cover off, and cleaned it up. The teeth in all the gears are nice. In the video you can see the play in the input shaft. Can I just tighten that bolt to take the play out?
http://m.youtube.com...h?v=vdLe3X_WoHM
#12 massey driver ONLINE
massey driver
  • 1,422 Thanks
  • 1,576 posts
Posted August 09, 2015 - 07:01 PM
sorry I can't watch videos . removing that nut with the proper socket and a impact wrench shouldn't be a problem. as for the input shaft [remeber I can't watch videos] being loose and wobbling if thats what its doing there is a needle brg right at the front of the gear box and a common brg a little further inside.so if either brg is worn or the shaft is worn its going to cause the shaft to be loose.
#13 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted August 09, 2015 - 07:14 PM
I looked at the video and then had a look at some of the photos I took when I was inside my BGB.  I think the threads look like they are normal threads.  As for the play issue, it looks like your woodruff key (26), or the associate key-way, is worn.
#14 Dayton_King ONLINE
Dayton_King
  • 1,256 Thanks
  • 1,052 posts
Posted August 09, 2015 - 07:15 PM
There is no play in the input shaft. I can rotate the input shaft and the bevel gear will start turning an 1/8 of an inch later
#15 Dayton_King ONLINE
Dayton_King
  • 1,256 Thanks
  • 1,052 posts
Posted August 09, 2015 - 07:18 PM
Well looks like I run it as is or fix the problem. I will go with fix the problem. Does any body rebuild the bvg I don't have a shop press. Or do you think I can make due and do it?
