Here is one for you
4 replies to this topic
#1 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,879 Thanks
  • 6,358 posts
Posted August 01, 2015 - 03:41 PM
Dad picked up a super cheap 128. Ran fantastic. He has used it a half dozen times no issue probably 4 hours per session. Until today. you mow for about 10 minutes then it shuts off. If you hurry up shut the blades off push the brake in and lower the throttle all the way down she will stay running. Try to give it more throttle it dies and wont restart until you charge it for about 15 minutes.
New battery same result dead battery no start.
Now we are pretty familar with the cub electrics. It is not charging. We have had numerous problems with regulators but never had one not run till it was shut off after jumping. I am leaning towards a failed/failing generator. It appears to be running solely off the battery to me.
But to throw in another curve it has only done it so far going down hill. Coincidence? I do not believe to be fuel related.
  • Traill95 said thank you
#2 MH81 OFFLINE
  • 29,979 Thanks
Posted August 01, 2015 - 06:16 PM
Dead battery as in no crank, or dead battery, it will crank but not start?
I'm wondering if the 15 minutes is a cool down period and the coil or condenser is breaking down.
Have you taken any voltage readings? Running, not running, etc?
#3 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,879 Thanks
  • 6,358 posts
Posted August 01, 2015 - 06:31 PM
I haven't yet. Battery dead in as no crank at all. Not even enough juice to make the solenoid click.
#4 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,122 Thanks
  • 10,191 posts
Posted August 01, 2015 - 08:30 PM
If it's not charging, wouldn't you think it would run for more than four hours on the battery? Unless you have a short somewhere. Especially a 'going down hill' short? Just thinking out loud.
  • toomanytoys84 said thank you
#5 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted August 01, 2015 - 08:38 PM
Sounds like the starter/generator is sticking in start mode & draining the battery.  A bad regulator can cause it to happen.
  • MH81 and toomanytoys84 have said thanks
