New Project
320 replies to this topic
#91 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted August 30, 2015 - 11:43 AM
I need something to hold it when parked on a hill as it will freewheel when the engine is shut off!
That must be a Ford thing because my GT18H is the only one I have that does that too.  I thought maybe something was just worn out.
#92 MH81 OFFLINE
Posted August 30, 2015 - 02:27 PM
I may have you make me a decal for the console. Something stating to shift Hi/Lo to neutral and setting the brake when leaving the tractor. These things will freewheel with the engine off!
The Roper will pull that stunt too.
#93 olcowhand ONLINE
  • 42,372 Thanks
  • 31,796 posts
Posted August 30, 2015 - 03:10 PM
Kinda odd, as the Eaton my former Unico 15 (now DHI's) didn't freewheel as I remember.
#94 KennyP OFFLINE
  • 40,130 Thanks
  • 46,764 posts
Posted August 30, 2015 - 04:32 PM
Got a little accomplished today! First on the agenda was some clean up of the place.
Then I started to look into a parking brake. Not much room in there, so I moved to the cylinder location. That was bad news!!!
Little did I know this is only a 3" stroke cylinder and I need 4"!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Everything is now on hold until I can have one shipped in!
  • Alc, wvbuzzmaster, Cvans and 2 others have said thanks
#95 TomLGT195 OFFLINE
TomLGT195
  • 4,015 Thanks
  • 2,883 posts
Posted August 30, 2015 - 05:57 PM
Is the cylinder for the 3pt hitch? I must have missed that earlier.
#96 olcowhand ONLINE
  • 42,372 Thanks
  • 31,796 posts
Posted August 30, 2015 - 06:03 PM
Can you just shorten the arm the cylinder connects to, or would it throw too much stress on it?
#97 KennyP OFFLINE
  • 40,130 Thanks
  • 46,764 posts
Posted August 30, 2015 - 06:11 PM
Yes.
I have no way to figure how much it needs shortened, plus I have it offset to clear the brake!
  • olcowhand and TomLGT195 have said thanks
#98 KennyP OFFLINE
  • 40,130 Thanks
  • 46,764 posts
Posted August 30, 2015 - 06:34 PM
I only have a spot just over 2.5" wide for a cylinder to go in. I sold the other cylinder I had as I thought this was the same. I haven't a clue on where to use such a short stroke cylinder, so it will probably be scrapped. This whole project is on hold until I find a Ford cylinder with 4 " stroke!
  • olcowhand said thank you
#99 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted August 30, 2015 - 07:36 PM
The Ford cylinders are 3.75" stroke if my memory serves me correctly.
#100 KennyP OFFLINE
  • 40,130 Thanks
  • 46,764 posts
Posted August 31, 2015 - 03:44 AM
That's better than 3"!
#101 KennyP OFFLINE
  • 40,130 Thanks
  • 46,764 posts
Posted August 31, 2015 - 04:23 AM
I will look into that this morning, Daniel.
#102 KennyP OFFLINE
  • 40,130 Thanks
  • 46,764 posts
Posted August 31, 2015 - 11:50 AM
Update! Daniels suggestion worked! I shortened the arm the cylinder attaches to and moved the rear cylinder mount and I now have a usable condition! This time I only tack welded things together!
I got about 60° degrees of angle.
Here it is with the lower arms on it.
  • olcowhand, MH81, wvbuzzmaster and 2 others have said thanks
#103 olcowhand ONLINE
  • 42,372 Thanks
  • 31,796 posts
Posted August 31, 2015 - 11:52 AM
Good deal!  :thumbs:  I figured this would work, plus save some cash!
#104 TomLGT195 OFFLINE
TomLGT195
  • 4,015 Thanks
  • 2,883 posts
Posted August 31, 2015 - 04:01 PM
Was this the one you sold to me?
#105 KennyP OFFLINE
  • 40,130 Thanks
  • 46,764 posts
Posted August 31, 2015 - 04:49 PM
Yes! But all is well now!
Got the fenders mocked up and did a little more for the brakes. The compression spring I bought for the brakes was lacking some tension, so I went to plan B there. No pics of that yet. But here's some of the fenders. I want to move them forward some more but the foot boards are in the way. Plus I want to go inboard an 1". Think that will have them about right over the tires. Might go a little higher in case I find some more 26X12's! :smilewink:
Tomorrow morning I will remove the foot boards and see what transpires from there!
  • wvbuzzmaster, Newpaws493 and TomLGT195 have said thanks
