New Project
320 replies to this topic
#46 KennyP ONLINE
  • 38,354 Thanks
  • 45,921 posts
Posted August 16, 2015 - 12:16 PM
I made a crossmember to fit in where the BGB used to bolt up. It is 1/4" plate and 1/8"+ wall square tube. Trying to decide if I want it to be welded solid to the rest of the frame work. That's probably best, though.
I need to get the foot/running boards back on to see what issues they may cause. Especially with the foot pedal. So I better get them trimmed to fit. Back in post #42, second pic you can see the lever that controls fwd./rev. just above the 1" square tube about center of the pic. If the foot boards are below the 1", I will have to get real creative to get that to work.
  • skyrydr2, Newpaws493 and holdenboy1960 have said thanks
#47 KennyP ONLINE
  • 38,354 Thanks
  • 45,921 posts
Posted August 16, 2015 - 03:25 PM
Well, the 'stock' foot boards are not going to work. Got one out and mocked it up with an 1-3/4" spacing to see where I needed to cut. Way too far in from the tire and just not what I am looking for. Guess I need some tread plate to make my own!
I got the tires swapped around like I want and it should make a decent plow tractor as the inside of the rears lines up well with the inside of the skinny's up front! Thought I would take it out side for a photo op. It rolls very easily!
The third pic was taken more to the RH side to show how well that side lines up!
  • coldone, wvbuzzmaster, sacsr and 4 others have said thanks
#48 KennyP ONLINE
  • 38,354 Thanks
  • 45,921 posts
Posted August 16, 2015 - 05:53 PM
Guess I need to make this a "Caption This" thread!
  • wvbuzzmaster said thank you
#49 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted August 16, 2015 - 06:19 PM
Big Bertha gets a little stable competition.
#50 KennyP ONLINE
  • 38,354 Thanks
  • 45,921 posts
Posted August 21, 2015 - 07:00 PM
Got the Kohler set in place, but need to adjust it some!
May have to raise it 3/16" or 1/4" to sit right. Having a very hard time seeing the mount holes!
  • olcowhand, Alc, wvbuzzmaster and 4 others have said thanks
#51 olcowhand ONLINE
  • 41,166 Thanks
  • 31,423 posts
Posted August 21, 2015 - 07:03 PM
Moving right along Kenny!  Will this be mostly for use as a plow tractor, or just whatever you need it for?   You not going to try putting a deck under it?
  • KennyP and holdenboy1960 have said thanks
#52 KennyP ONLINE
  • 38,354 Thanks
  • 45,921 posts
Posted August 21, 2015 - 07:19 PM
I have no deck for it. That's why I pulled the center lift mechanism. Mostly a plow tractor or other 3-point implements. May try to work in front blade or such!
From what I can see at the moment, it is dead even with the Eaton input height wise. I don't think raising it a smidgen will hurt anything with the u-joint drive shaft.
  • olcowhand, wvbuzzmaster, skyrydr2 and 1 other said thanks
#53 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted August 22, 2015 - 12:32 AM
looking good so far but all takes time
#54 KennyP ONLINE
  • 38,354 Thanks
  • 45,921 posts
Posted August 22, 2015 - 03:49 AM
Going to be working on this most of the weekend. I need to make some brackets so I can use a cherry picker for pulling the engine out. Also, looking into some 1/4" strap to make motor mounts as it looks real hard to get to any mount bolts. Thinking about drill & tap holes for short studs to bolt the strap to the engine and to bolt through the original engine mount holes. I need to trim just a tad more on the LH frame side to clear an engine tin. I'll have pics!
  • olcowhand, skyrydr2 and Cvans have said thanks
#55 KennyP ONLINE
  • 38,354 Thanks
  • 45,921 posts
Posted August 22, 2015 - 07:26 PM
Got the engine bolted in! The driveshaft is too long :dancingbanana:  so I can shorten it. I don't have any way to hook up to the 1" end of that u-joint, so waiting for my other driveshaft to arrive.
I got the Hi/Lo  all complete! Trying to figure out the seat location now. I don't have enough large pieces of sheetmetal to cover what I would like to. I would rather not use small pieces to be welded together.
Here's what I did for the engine mounts.
Had an issue with the starter post being close to the frame so I used a hole saw to fix that,
Here's a pic from the front. The hood won't fit right now due to the crank being in the way!
The exhaust will be an issue as there is not much room to the grille!
  • Alc, wvbuzzmaster, Cvans and 1 other said thanks
#56 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted August 22, 2015 - 07:49 PM
Good progress. Are you going to cut a hole in the grill to run a front belt pulley?
#57 KennyP ONLINE
  • 38,354 Thanks
  • 45,921 posts
Posted August 22, 2015 - 08:10 PM
There will be a hole there as I will not cut the crank! Just need to see what is needed so I can open and close the hood. The whole hood and grille are one piece!
#58 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted August 22, 2015 - 08:15 PM
Divide the hood from the grille to conquer the dilemma.
#59 KennyP ONLINE
  • 38,354 Thanks
  • 45,921 posts
Posted August 23, 2015 - 05:42 AM
That would be a whole project on it's own! It is spot welded about every inch!
#60 skyrydr2 OFFLINE
  • 3,900 Thanks
  • 3,411 posts
Posted August 23, 2015 - 06:38 AM
Add a little length to the hood and frame to get out past the crank. Then it can cover up a pto set up for future use, like maybe a front mounted rake or broom, or even a hydraulic pump for a loader ;-)
