New Project
320 replies to this topic
#31 KennyP ONLINE
  • 40,989 Thanks
  • 47,156 posts
Posted August 09, 2015 - 01:53 PM
A Frankentractor? I'm using the front section from a 716, but putting an Eaton 10/Peerless 2500 in the back! Plus a 3-point lift!
#32 KennyP ONLINE
  • 40,989 Thanks
  • 47,156 posts
Posted August 09, 2015 - 02:00 PM
I played with it some more today! The steering was still stiff and I traced that back to the column. So out it came! Took everything apart and cleaned the crud out.The gears were packed full of dirt. And the bushings were rusty/crusty! A little TLC and it does much better now.
Got it back together and waiting for a drive shaft now.
  • olcowhand, wvbuzzmaster, Cvans and 1 other said thanks
#33 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted August 12, 2015 - 04:00 PM
Great way to do a 3pt on a AC. I really like it.
#34 Cvans OFFLINE
  • 7,308 Thanks
  • 6,392 posts
Posted August 12, 2015 - 06:11 PM
Your project looks  like fun. Whatcha going to call it? Frankentractor has already been taken.  :smilewink:
#35 KennyP ONLINE
  • 40,989 Thanks
  • 47,156 posts
Posted August 12, 2015 - 06:15 PM
Not sure! It's an Allis in the front half, but Ford & Sears out back! Thought about AlFord till the Sears got into the mix!
  • Alc and Cvans have said thanks
#36 shorty ONLINE
shorty
  • 5,839 Thanks
  • 5,421 posts
Posted August 12, 2015 - 09:26 PM
We can give you many suggestions on what to name it.
#37 KennyP ONLINE
  • 40,989 Thanks
  • 47,156 posts
Posted August 15, 2015 - 11:47 AM
Update! Been working on this some more. Yesterday, I clean up the 3-point and painted it. Looks much better!2015-08-15 09.03.13.jpg
Worked on the fittings for the Hyrdo fill and vent.
Got to measuring and found that the Eaton input shaft is 3/4" off center to the right side. So I had to open the hole through the Allis frame some more to clear the u-joint.
Then it was time to align things up since I now have a drive shaft. Took a few tries, but I have it close. Still out to a 50" wheelbase.
Here you can see the white mark for center of the Eaton to align too.
Since I was mocking things up, I threw on a few more things to get an idea how it looks.
Now to decide if I want this wheelbase or to take it back to 48"!
  • wvbuzzmaster and Newpaws493 have said thanks
#38 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted August 15, 2015 - 11:59 AM
Compromise to 49"?
Looking great Kenny.
#39 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Posted August 15, 2015 - 01:44 PM
I prefer the longer wheelbase for ground engagement work. The front end doesnt lift off as much.
#40 olcowhand OFFLINE
  • 42,900 Thanks
  • 31,942 posts
Posted August 15, 2015 - 05:21 PM
Good progress Kenny.  You're gonna get this finished by spring for sure.
#41 KennyP ONLINE
  • 40,989 Thanks
  • 47,156 posts
Posted August 15, 2015 - 05:23 PM
I hope to be driving it around this Fall!
  • olcowhand and wvbuzzmaster have said thanks
#42 KennyP ONLINE
  • 40,989 Thanks
  • 47,156 posts
Posted August 15, 2015 - 05:31 PM
Got some more done today! I think I could put a jack under the back and swap the tires around now!
#43 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted August 15, 2015 - 06:05 PM
Any diagonals in the plan, or plate steel all the way?
#44 KennyP ONLINE
  • 40,989 Thanks
  • 47,156 posts
Posted August 16, 2015 - 05:20 AM
Been thinking that over Casey. I am looking at another mount point using the 2 lower holes from where the BGB was mounted. That will go down to the 1" X 1" square tube on a cross brace. I'll muddle that over and see what else may be needed. Trying to not use too much plate so the heat can escape.
I am rethinking that under seat fuel tank as it raises the seat way up there. I have a 3(?) gallon tank that may fit under the hood. Have to get the engine set in there to see.
  • wvbuzzmaster said thank you
#45 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted August 16, 2015 - 06:43 AM
I have never had any heat issues with my Eaton 11 units!! Make that thing rugged!! You don't want it twisting and folding up there!! That's a great point for mounting attachments like a grader blade or FEL ;-) . looking pretty cool so far Kenny keep on truckin'
