New Project
320 replies to this topic
#16 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted August 02, 2015 - 04:58 PM
If you need anything machined let me know
  • KennyP, Newpaws493 and jacquelinezq60 have said thanks
#17 KennyP ONLINE
  • 41,525 Thanks
  • 47,427 posts
Posted August 06, 2015 - 05:18 PM
Found 2 drive shafts! But one is missing a u-joint! Anybody know what will replace it?
#18 KennyP ONLINE
  • 41,525 Thanks
  • 47,427 posts
Posted August 08, 2015 - 05:21 PM
I did some more today! I flipped the front section upside down and pulled the front axle. The drag link was seized on one end and not adjustable. After some heat and Acetone/ATF, it loosened up. The tie rod is non-adjustable, that is getting changed!
I'll use the short one from these.
Got the center lift shaft out as I do not plan for one.
Here's the guide I made up to open the BGB hole to 3".
 Here's the ring I cut out of the hole. Lots of oil for the hole saw.
The plate there is about 1/2" thick!
The Ford tiller u-joint has plenty of room to go through.
And for the banned guest following this, I will make this work and look decent! You haven't a clue how to build a tractor like this, so just go away!
  • olcowhand, limebuzz, wvbuzzmaster and 4 others have said thanks
#19 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted August 08, 2015 - 05:25 PM
Looking great Kenny. Don't let anyone get you down on this project. If it looks too crazy to work.... It usually will lol. :thumbs:
  • KennyP and skyrydr2 have said thanks
#20 KennyP ONLINE
  • 41,525 Thanks
  • 47,427 posts
Posted August 08, 2015 - 05:30 PM
Doing my best Casey! But, I wish Ray would check this out! I value his opinions!
  • wvbuzzmaster and skyrydr2 have said thanks
#21 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted August 08, 2015 - 05:38 PM
Is Ray still in the middle of his move / setting up his new shop (assuming he is that far along)? I haven't seen much posting from him (unless I'm blind and not noticing).
#22 KennyP ONLINE
  • 41,525 Thanks
  • 47,427 posts
Posted August 08, 2015 - 05:41 PM
Not sure what he is up to right now! He has posted some, but may be moving!
  • wvbuzzmaster said thank you
#23 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Posted August 08, 2015 - 06:18 PM
Love the idea for the hole saw guide. Thanks, that will come in handy. Cant wait to see this up and running.
#24 KennyP ONLINE
  • 41,525 Thanks
  • 47,427 posts
Posted August 08, 2015 - 06:25 PM
I use them often for boring through steel. No need for the center bit! It's easier on a drill press, but no way to get this under it!
#25 Alc OFFLINE
  • 7,357 Thanks
  • 7,639 posts
Posted August 08, 2015 - 07:24 PM
Kenny do GT size u joints differ much compare to truck size pto shafts like what would have been on our older trucks at work ?
#26 KennyP ONLINE
  • 41,525 Thanks
  • 47,427 posts
Posted August 08, 2015 - 07:40 PM
Yes, they are smaller! Less mass to spin!
#27 Alc OFFLINE
  • 7,357 Thanks
  • 7,639 posts
Posted August 08, 2015 - 08:25 PM
Kenny in the back of the SKF universal joint catalog there are pto u joints shafts yokes listed by size and also pictures if that helps you sorry can't post the link will this note book
Edited by Alc, August 08, 2015 - 08:26 PM.
#28 KennyP ONLINE
  • 41,525 Thanks
  • 47,427 posts
Posted August 09, 2015 - 06:31 AM
I'll have to have the shaft here so I can cross the u-joints! Thanks!
I looked at the 716 Parts Manual and the tie rod is correct for this. Not sure why it's non-adjustable, though. I think I'll leave it for now as I can't seem to find any 3/8" IP that I was going to use for stretching the adjustable one. I believe I have a 7/16" rod with threads on one end out there somewhere. If it is long enough, I'll thread the other end so I can make the new one.
#29 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted August 09, 2015 - 07:03 AM
Paulbparts..com has pto shaft stuff and joints, but not the little tiny ones used by a lot of gt's for prop shafts to the transaxle. Personally, I would use the larger units, as they are easily serviced.
#30 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted August 09, 2015 - 09:57 AM
How did I miss this??
Kenny, what exactly are you trying to build?? I can see all the 716 stuff but what is your final build going to be??
