New Project
320 replies to this topic
#136 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted September 05, 2015 - 04:12 PM
Reply attempt three...
Looking excellent Kenny. I can't wait to see you driving it around later this week.
#137 olcowhand ONLINE
  • 42,896 Thanks
  • 31,939 posts
Posted September 05, 2015 - 04:13 PM
She's coming together!  She has a long lean look that I think 26x12/12's along with 18x8.50/8 fronts would look fantastic.  With the pto clutch remounted, are you thinking of putting a deck under her after all?
  Are you gonna mount the cooler near the flywheel intake?
#138 KennyP ONLINE
  • 40,874 Thanks
  • 47,091 posts
Posted September 05, 2015 - 04:26 PM
I'll stay with skinny's up front! The Pto clutch can be used for several options besides a deck! The cooler will go where you said, after I get the drive shaft installed.
  • wvbuzzmaster said thank you
#139 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted September 05, 2015 - 06:46 PM
Tomorrow, I have to haul an antique cabinet from Tulsa to Okmulgee, so not GT pics there!
You never know. Something just might jump into the empty truck on the way home!
Looking good. :thumbs:
#140 KennyP ONLINE
  • 40,874 Thanks
  • 47,091 posts
Posted September 07, 2015 - 04:46 PM
I saw a PK, but they wanted $500 for one with 4 flats and not sure if it would run!
I got back into it today! Got the HF head lights Alan talked about here. Hope they aren't too big!
Changed out the FWD. pedal to the Ford brake pedal! Gives a bit more foot room.
Started on the lift lever handle & linkage. This will be a short stroke linkage, hope it works out okay.
Steve got started on the hood!
I'll use Matrix brand paint, single stage with hardner added.
  • olcowhand, MH81, Texas Deere and Horse and 3 others have said thanks
#141 olcowhand ONLINE
  • 42,896 Thanks
  • 31,939 posts
Posted September 07, 2015 - 04:53 PM
The short stroke should work ok, as the valve shafts don't move all that far on GT's.
#142 Texas Deere and Horse OFFLINE
  • 14,887 Thanks
  • 15,514 posts
Posted September 07, 2015 - 05:19 PM
Wow Kenny, you have made a lot of headway while I have been MIA. That is really looking great and it is going to be a real workhorse for sure. Won't be long til you get her all done. Great Job Kenny!!
#143 KennyP ONLINE
  • 40,874 Thanks
  • 47,091 posts
Posted September 07, 2015 - 05:22 PM
Brian, great to hear you chiming in here! It's taking a lot of thought before I do anything. But, I'm trying to build a dream tractor!
#144 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted September 07, 2015 - 05:41 PM
Looking great Kenny.
#145 KennyP ONLINE
  • 40,874 Thanks
  • 47,091 posts
Posted September 08, 2015 - 07:08 AM
I think I'll rework this a little as I don't like the handle shaft mounting as it is. I am also thinking about trying to 'feather' the action, especially with box blade use. Sometimes you only want to lift/lower just a tad and that's hard to do. With a longer stroke on the handle, that may help this. Plus I may be able to bush the valve down from the plate to help dissipate the heat.
  • olcowhand and Texas Deere and Horse have said thanks
#146 olcowhand ONLINE
  • 42,896 Thanks
  • 31,939 posts
Posted September 08, 2015 - 08:37 AM
Needing to alter things as you're in "discovery" is one reason I didn't want to paint Hogzilla for a long while.  I knew there would be things I would want to change, so I waited on paint.
  • KennyP and Cvans have said thanks
#147 Cvans ONLINE
  • 7,279 Thanks
  • 6,373 posts
Posted September 08, 2015 - 08:40 AM
From experience I would say this is excellent advice.
  • olcowhand and KennyP have said thanks
#148 KennyP ONLINE
  • 40,874 Thanks
  • 47,091 posts
Posted September 08, 2015 - 05:42 PM
That's why i spend the time to think about what I am doing & what will it do to something else. I spent nearly all day on the valve location!
First off was some clearance for the lines!
Then to temp the valve location.
Then I began to make a mount for it.
Here it is. The handle will be just to the right of my thigh. Great spot!
  • olcowhand, Texas Deere and Horse, Newpaws493 and 1 other said thanks
#149 olcowhand ONLINE
  • 42,896 Thanks
  • 31,939 posts
Posted September 08, 2015 - 05:46 PM
The valve location looks to be great Kenny.  You're rolling right along!
#150 KennyP ONLINE
  • 40,874 Thanks
  • 47,091 posts
Posted September 08, 2015 - 06:09 PM
I think it's time to make a list of what else is needed done.
 No particular order:
Parking Brake
Fuel tank (just got the new fitting for it)
Drive Shaft (waiting for the second one to arrive)
Hydraulic lines
Hydraulic filter mount.
Oil cooler mount
Wiring (adding in an oil pressure gauge)
Mount headlights
Exhaust
PAINT
That's about it as far as I can tell at the moment!
Edited by KennyP, September 09, 2015 - 05:03 AM.
