New to the forum, R608P Starting Issues
starting carburation
6 replies to this topic
#1 gmanracer OFFLINE
gmanracer
  • 2 Thanks
  • 4 posts
Posted August 01, 2015 - 12:19 PM
Hi All, brand new to the forum and hopefully will not make a fool of myself or waste anyone time.
Have a MTD R608P - Tractor Supply Brand 25hp / 54.00" riding tractor.
Recently while mowing motor died.
Did all of the normal checks
-have spark (at the plugs)
-fuel pump wworking (pumps strong when ignition is on)
-Cranks strong and "sounds like" it trying to fire, but will not.
Disassembled the carb, cleaned - did not see anything abnormal
Same problem exists
I see where folks are mentioning the soleniod that plugs into the float bowl. Is there a way to by-pass this to determine if this might be my problem?
Any suggestions, questions or theories are welcome.
Gman racer in Texas
#2 boyscout862 ONLINE
  • 13,446 Thanks
  • 9,392 posts
Posted August 01, 2015 - 01:48 PM
Welcome to GTT. Check our Manuals Section(3 free downloads per day) for the engine manual. It should have a troubleshooting section to test the shut off solenoid. Good Luck, Rick
Edited by boyscout862, August 01, 2015 - 01:48 PM.
#3 HDWildBill OFFLINE
  • 8,978 Thanks
Posted August 01, 2015 - 04:40 PM
Welcome to GTt.  If your carburetor had a fuel shutoff you would have seen it when you pulled the carburetor for cleaning.  It normally screws into the float bowl.  What happens if you shoot starter fluid down the throat of the carburetor?  Also it would be helpful if you could tell us what engine you are working on.
#4 MH81 OFFLINE
Posted August 02, 2015 - 07:23 AM
This really sounds a newer Briggs I had that would run for a while, then quit.
Like you, I had good fuel and spark... But didnt have correct compression.
Turns out, the engine would heat up, valve guide swelled, and cause the valve to not to move (close) correctly.
Only way to check compression is with a tester.
BTW, I was able to get about another 10 minutes + by running 93 octane gas mixed for my chainsaw (50 to one).
Supposed fix according to my mechanic is to remove valve and hone the guide.
I know another guy who had fractional drill bits and hand ran the next size up thru, but I would imagine he may have used a little oil afterwards.
#5 gmanracer OFFLINE
gmanracer
  • 2 Thanks
  • 4 posts
Posted August 03, 2015 - 04:15 PM
Thank you for the quick replies. I will take a look at the manuals tonight and provide the engine data.
Did try the started fluid trick...absolutely nothing. That led to my initial thought that there was something blocking fuel from reaching the carb.
Speaking of, one more bit of information...the plugs are basically dry when I pull them (not soaked as you might think when cranking away).
Unfortunately, you valve theory sounds plausable....Mowing in the 100 degre heat, you see a noticable loss in performance after it really heats up. I suspect everything is getting sloppy.
I work on racebikes for fun....never thought I be diving in this deep on my lawn tractor..........
#6 gmanracer OFFLINE
gmanracer
  • 2 Thanks
  • 4 posts
Posted August 05, 2015 - 04:28 PM
The engine model is series 440000
446777
#7 gmanracer OFFLINE
gmanracer
  • 2 Thanks
  • 4 posts
Posted August 09, 2015 - 08:19 PM
Finally back in town and was able to test compression.
Left - 150+psi
Right - 50psi
As Boyscout862 suggested, I'm going to find the manual online.
Sounds like I might have a stuck valve.
Would anyone happen to know what compression should be?
