Cast front axles
64 replies to this topic
#46 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted August 13, 2015 - 06:03 PM
OK it's in shape enough to put on and pull with. I'll take it off again after the weekend and finish it. I'm leaving the top flat because I don't want it to pivot anymore.
#47 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted August 13, 2015 - 06:04 PM
  • olcowhand, Alc, wvbuzzmaster and 2 others have said thanks
#48 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted August 14, 2015 - 04:33 AM
Are you going to pull this weekend at the Bolton fair?
  • Chris11 and Cvans have said thanks
#49 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted August 14, 2015 - 06:45 AM
I'll be there. My son and a friend of mine are going to pull.
#50 DaveBb OFFLINE
DaveBb
  • 405 Thanks
  • 173 posts
Posted August 19, 2015 - 07:30 AM
First class as always Chris :thumbs:
  • Chris11 said thank you
#51 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted August 22, 2015 - 12:00 PM
OK I'm trying to get this done for the next pull. Just doing some detail work before I buff it.
  • Alc, wvbuzzmaster and LilysDad have said thanks
#52 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,112 Thanks
  • 10,183 posts
Posted August 22, 2015 - 12:16 PM
How much weight did you save over the stock axle?
#53 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted August 22, 2015 - 12:25 PM
12 lbs so far
  • wvbuzzmaster and LilysDad have said thanks
#54 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted August 22, 2015 - 03:51 PM
Why paint it?
#55 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,112 Thanks
  • 10,183 posts
Posted August 22, 2015 - 05:57 PM
I think if I went to all that work to make something custom and special, I'd want to buff it up and let everyone see it. You know they are going to ask where you bought it. And your going to tell them. . . . .
#56 Cvans ONLINE
  • 7,289 Thanks
  • 6,377 posts
Posted August 22, 2015 - 07:23 PM
Mark me down for leaving it polished.  :thumbs:
#57 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted August 22, 2015 - 07:46 PM
sending the spindles out Monday to be plated.
Edited by Chris11, August 22, 2015 - 07:47 PM.
#58 Alc ONLINE
  • 7,226 Thanks
  • 7,578 posts
Posted August 23, 2015 - 05:50 AM
How does the weight savings help out on your tractor ? I see some pullers put weight on in different places so they can run different classes . Is this so you can have a lower starting class ?
#59 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted August 23, 2015 - 06:56 AM
That tractor has a heavy engine in the front . I want to take weight off so I can put it on where I want. When I run the 900lbs class I take off the weight rack just to make it lighter. then I run the 1200 lbs class I put it back on.
#60 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted August 23, 2015 - 07:18 AM
This is a 900lb class pull when the tractor and me have to weight 900 lbs . And the picture on the right is pulling in the 1200lb class.
  • olcowhand and Alc have said thanks
