Cast front axles
64 replies to this topic
#16 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted August 01, 2015 - 10:24 PM
My cub cadet
#17 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted August 01, 2015 - 10:42 PM
I could make one out of chrome molly steel
That is what I see all the hot rod pullers running around here, I think it would be a wise choice.
#18 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted August 01, 2015 - 10:49 PM
My cub cadet
I am surprized to not see a weight bar on the front to help hold the front end down.
Do they not have a limit as to how high the front end can be off the ground.
Most pullers have wheelie bars that limit how far you can pull the front up it is required in the associations out here.
#19 MH81 OFFLINE
Posted August 02, 2015 - 07:29 AM
Sorry about the luck Chris,
I've slammed down a couple of times, but the 81 always bounced and recovered.
It's hard to wince, brace yourself, brake, and clutch all at the same time :D
Lower tire pressure may have helped?
  • Chris11 said thank you
#20 DaveBb OFFLINE
DaveBb
  • 405 Thanks
  • 173 posts
Posted August 02, 2015 - 08:06 AM
Yikes thats a hard hit
#21 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted August 02, 2015 - 08:11 AM
It was wheelie bars That doesn't allow it to go over 14 inches. And has weight bar. In the 900 lbs class I was running I never needed to weight it up. Like I said the tires just grabbed and it went up. Pulling on concrete isn't the same as dirt. You have to get the tires hot before the grab. It just happen to fast.
Edited by Chris11, August 02, 2015 - 08:19 AM.
#22 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted August 02, 2015 - 08:53 PM
Sorry to hear that chris. My diesel did the same thing. It was a hard wet clay track and i rode a good 20 feet with the front end up off the ground before it came back down and broke in half. My dad being a fabricator he made me a custom aluminum tube front axle. If i remember correctly it weights roughly 5 pounds.
#23 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted August 02, 2015 - 09:03 PM
I can make one out of billet aluminum. Or one made out of 4130
#24 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,014 Thanks
  • 9,644 posts
Posted August 03, 2015 - 07:28 AM
Are these hard landings frequent? The axle may have had stress cracks before it broke?
Having said that, is it possible to spring mount the axle or use a hard rubber bushing? Just a thought.
#25 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted August 03, 2015 - 09:26 AM
it landed hard because I had to hit the brakes. I was coming up to the end of the pad. If I hit the grass at the end they would have disqualified me. So I tried to stop it.
#26 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted August 07, 2015 - 09:57 AM
Got The axle out last night. and glued it back together
#27 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,014 Thanks
  • 9,644 posts
Posted August 07, 2015 - 01:09 PM
Yeah! That'll work. :thumbs:
  • Chris11 and KennyP have said thanks
#28 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted August 07, 2015 - 01:29 PM
Works on TV. Heres the new one in the band saw
  • LilysDad said thank you
#29 KennyP ONLINE
  • 37,547 Thanks
  • 45,533 posts
Posted August 07, 2015 - 04:20 PM
Where's the saw?
#30 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted August 07, 2015 - 06:01 PM
Sorry I had wrong picture up
  • KennyP, EricR and LilysDad have said thanks
